Runtime content crashes on 64 bit devices
4811
10-07-2015 10:01 AM
raffia
- Using the ArcGIS iOS SDK specifically on ARM 64-Bit, a consistent crash always happen when attempting to solve a route offline. The stack trace always returns the following function:
Esri_runtimecore::Network_analyst::Traversal_result::get_partial_edge_geometry_(Esri_runtimecore::Geodatabase::Transportation_network_view::Source_object_range, std::__1::shared_ptr<Esri_runtimecore::Geometry::Geometry> const&, std::__1::shared_ptr<Esri_runtimecore::Geometry::Polyline>&, bool, double, double) const ()
- Given the declaration, I'm inclined to suspect that a 64-Bit pointer is being casted to a 32-Bit variable (or something similar). Please note that that doesn't occur on ARM 32-Bit. I'm not currently certain whether this issue exists with other similar Esri_runtimecore functions or not.
Thanks for any feedback
DiveshGoyal
Thanks for reporting this. Your initial suspicion is probably right. We will look into it.
raffia
Thank you for replying.
DavidChambers1
New Contributor III
I encountered this as well.  As raffi a​ mentioned you can workaround this issue on devices that have a 64-bit ARM processor by changing the build settings architecture section to build for armv7 instead.   In the section in xcode change 'Architectures' to '$(ARCHS_STANDARD_32_BIT)' and change 'Valid Architectures' to armv7 only.  Screenshot 2015-12-02 13.33.48.png
梦竹许
I'm sorry to disturb,I have the same crash with you when i using the RouteTask of ArcGis, and i do as the last replier said ,but i met new mistakes. Because i used Afnetwoking and so on, it support arm64 only ,so i guess how i can solve th problem, would you give me some suggestions?  Thanks.屏幕快照 2016-04-19 上午10.58.25.png屏幕快照 2016-04-19 上午10.58.55.png
