Making the Results of a Flow Accumulation Meaningful
2197
10-07-2015 03:19 PM
RachelAlbritton
Occasional Contributor III
DarrenWiens2
MVP Honored Contributor
Are you only interested in the drain itself (i.e. how much water goes down the drain) or do you need to consider the drainage system itself (e.g. this drain + this drain = this accumulated drainage going through the pipe)?
