enahnced search widget buffer not showing
3904
7
10-13-2015 05:15 PM
JeffGarland_AGOL
I'm working on upgrading to latest version of the Enhanced Search Widget (3.7) and having problems with the Buffer option on the spatial search not showing up.  Attached is a screen shot.  It worked on the previous version and I'm using the same config file.  Any help appreciated.esearchshot.png
RobertScheitlin__GISP
Jeff,
   Be sure to mark this thread as answered.
Jeff,
   Do you have this in the XML?
<enablegraphicsbuffering>true</enablegraphicsbuffering>
it looks like you are missing most of your labels for the graphical search tab. Can you post your xml?
JeffGarland_AGOL
Robert:
XML file is attached.  I would have thought I wouldn't have had to update the XML file with the upgrade to 3.7.  The buffer was working in the previous version. Thanks for taking a look at this.
Jeff,
   I have not worked with the Flex eSearch widget since February, so I can recall what I did in the code but the widget is working properly for the way you have it configured. If you want that search button in your image to go away then change:
<multipartgraphicsearch>true</multipartgraphicsearch>
to false. And if you want buffering to show on the "Graphical" search tab then change:
<enablegraphicsbuffering>false</enablegraphicsbuffering>
to true. Not sure why your config.xml worked differently in the previous version.
JeffGarland_AGOL
Robert.  Thanks for your help.  I migrated from the 3.0 Flexviewer to 3.7.  I'm inheriting the project from someone else and it obviously hasn't been updated in a couple of years.  I understand you're on to the WAB. Is there a buffer widget equivalent?  Searching AGOL I'm not finding anything short of the land use app.  Alternative is to build a quick app
Jeff,
  Going from 3.0 to 3.7, there was definitely changes in the XML.
Yes there is a WAB equivalent from many of my Flex widgets
Enhanced Search Widget Version 1.2.0.4 - 10/13/15
Roberts Custom WAB Widgets
JeffGarland_AGOL
Thanks again.  I was searching on AGOL with your user name.  It's a mystery to me where Esri keeps squirreling away user generated content.  I guess I'll start searching GeoNet.
Jeff,
