Error Adding Secure Services (Storing Credentials) 10.3
4822
10-14-2015 07:44 AM
ThomasSchultz
New Contributor III
Whenever I tried to add a secure service to Portal for ArcGIS as a new item, I get an error message.  The message will vary depending on what type of service it is, but for ESRI's routing service, for example, I get "Error Generating Token".  I've also tried to create a helper service proxy item according to the instructions:  Add premium helper services—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server, but this yields the same result.  All of the services I am trying to add can be added to ArcGIS Desktop without problem, so I've been focusing on the forward proxy settings for Portal.  I have configured Portal for our forward proxy according to the instructions I could find, but I am not sure if it is working.  I have a support ticket open with ESRI, but I am wondering if anyone else has successfully overcome this kind of issue.
ThomasSchultz
New Contributor III
After upgrading to Portal for ArcGIS 10.4, this problem has gone away.  I think the solution involved two things.  First, our forward proxy does cause issues when trying to store credentials.  I never go the proxy config settings to work correctly, but for now, whitelisting the sites has solved that problem.  Second, even this only worked after upgrading to 10.4, so I have to assume that there was a bug in version 10.3 causing a problem.
VHolubec
Dear Thomas,
have you found with Esri support some solution?
Thank you for reply.
Vladimir
Vladimir
ThomasSchultz
New Contributor III
I am actually still working with ESRI on this issue.  Still assuming it is being caused by our forward proxy, but have not found a solution either with ESRI or our Security group in IT.
ThomasSchultz
New Contributor III
MichaelKelly
Occasional Contributor III
You may also need to add your server certs to portal so they are trusted:
Configuring the portal to trust certificates from your certifying authority—Portal for ArcGIS (10.4....
Make sure you restart portal and clear your existing browser data.
