Changing the highlight color of the selection
5271
5
10-20-2015 03:46 AM
AveKargaja
I'm using uncompiled flex 3.7 in Flash Builder and trying to change the symbol used to highlight the feature that has been clicked on (to show popups). I know that it is possible, but I haven't been able to track down the specific location(s) to modify in the code. Therefore I would be very glad if somebody could point out  the file(s) I need to change and the code that I have to insert.
MattiasEkström
Occasional Contributor III
Take a look at this post: Re: change symbology of popup feature graphic
You need to add a style to the default.css.
EvelynHernandez
Well idk the exact file, but u can change the color in a graphic object, or eventually, for example, u do a query and when u get the featureset of the search u usually make a mappoint and a graphic object to display the search on the map. When u make the object, u specify the x,y of the mappoint and in the graphic the followings properties (kind of graphic: ppoint, polyline, polygon; the color; the alpha; etc). So try to see if u find something like that in ur code.
I hope this reference will be useful for you
EvelynHernandez
I found this post, it can help u: Map Highlight Color
AveKargaja
Thanks, I've read the topic refferred, but sadly it does not indicate the mxml file to insert the code.
MattiasEkström
AveKargaja
Thanks for the clues
The solution in my case was to add
map.setStyle('infoWindowRendererHighlightColor', 0x000000);
into InfoPopup.mxml file private function init():void section.
