WAB - Layer Control using Radio Buttons
2428
10-20-2015 08:28 PM
RodWoodfordOld
Occasional Contributor III
This is a general question does WAB have the functionality to allow for radio buttons (or exclusive layer access)? I would like to be able to click between imagery layers without the need to manually turn imagery layers on a off. See example below
cheers
Rod
RobertScheitlin__GISP
Rod,
   Not exactly what you are looking for but it could work for you:
https://community.esri.com/thread/182116-layerlist-21-option-to-displays-sublayer
RodWoodfordOld
Cheers Roberts,
Thanks for the info, I'll' take a look.
<http://www.bayswater.wa.gov.au> Rod Woodford
MANAGER GEOGRAPHIC SERVICES
61 Broun Avenue, Morley, WA 6062 PO Box 467, Morley, WA 6943
T: (08) 9272 0668 F: (08) 9272 0665
rod.woodford@bayswater.wa.gov.au www.bayswater.wa.gov.au
<https://www.facebook.com/bayswatercity> <https://twitter.com/cityofbayswater> <https://www.youtube.com/channel/UCQAoTYu-lDwIARC-X5cxVqg> <https://cityofbayswater.maps.arcgis.com/home/>
This email message and any attached files may contain information that is confidential and subject of legal privilege intended only for use by the individual or entity to whom they are addressed. Any unauthorised use, copying, circulation, forwarding, printing or publication of this message and/or attachments or disclosure of the information contained there in by the recipient, is strictly forbidden.
If you are not the intended recipient or the person responsible for delivering the message to the intended recipient be advised that you have received this message in error and that any use, copying, circulation, forwarding, printing or publication of this message or attached files is strictly forbidden, as is the disclosure of the information contained therein. If you have received this message in error, please notify the sender immediately and delete it from your Inbox.
