Geodatabase must be enabled as geodatabase admin user
15490
15
10-22-2015 01:58 AM
HaniDraidi
Occasional Contributor II
I've connected to an existing Oracle enterprise database, and I am trying to Geo-enable it  by using the "enable enterprise geodatabase" tool. However I get the following error: "Geodatabase must be enabled as geodatabase admin user. Failed to execute (EnableEnterpriseGeodatabase)."
I got confused, because I am connecting to this database as administrator, but I don't know why I am not able to geo-enable it.
Pieter_Geertvan_den_Beukel
"I am connecting to this database as administrator"
De geodatabase administrator is not the same as the Oracle administrator. You have to run this tool as the SDE user. See http://resources.arcgis.com/en/help/main/10.1/index.html#/The_geodatabase_administrator_in_Oracle/00...
HaniDraidi
Many thanks Pieter for the prompt input,
I am now connecting to the geodatabase using the "sys" user (which is the Oracle administrator, and not the one that should be used to enable the database to enterprise geodatabase), I've read that I should create an "sde" user that can administer the geodatabase itself. However, I am trying to create this "sde" user by right clicking the "sys" database connection and choosing "create user", but when i name the user as "sde", an error that says:
file:///C:/Users/Administrator/AppData/Roaming/ESRI/Desktop10.3/ArcToolbox/Dlg/MdDlgContent.htm#ERROR 000198
This tool cannot be used to create the geodatabase administrator user ‘sde’.
May you please elaborate more how can I create this "sde" user?
Best,
by Anonymous User
Not applicable
Just create the sde user in Oracle and assign it the proper privileges:
Privileges for geodatabases in Oracle—Help | ArcGIS for Desktop
HaniDraidi
Thank you Richard for the valuable contribution,
I've explored the resource you provided above, but actually, I am new to Oracle DB and don't know how to create this "sde" user and how to grant these previlliges. I've installed Oracle Server, client, and SQL Navigator on the machine, but don't know how to create users with them.
May you please elaborate more how can I create this user using this environment?
Your help is highly appreciated!
HaniDraidi
Hi Richard,
I've created the ''sde'" user, and assigned the required privileges except some privileges that I could not grant. In the screenshot below:
Can anyone help how I can grant them to this user?
AsrujitSengupta
Regular Contributor III
Use the 'Create Enterprise Geodatabae' tool. It can create the SDE user, table space, grant necessary permissions all by itself.
Also check out the two tools to get the use of each.
HaniDraidi
Dear Asrujit,
I tried your suggestion. However, the "create enterprise geodatabase" tool ended with the error below:
George_Thompson
Esri Frequent Contributor
That is an error when connecting to the Oracle database. Are you using TNSNAMES for connecting or EZConnect?
Try something like this: ServerName/SID (Server name that Oracle is installed on/Oracle SID Name)
That should get you past that error.
-George
--- George T.
HaniDraidi
Hi George,
I am using TNSNAMES. Also, I tried using "ServerName/SID", but the same error appeared again!
Best,
