Adding Geoprocessing to HTML or Java
4588
29
11-06-2015 02:46 AM
JasonSchelte
I am working on a project and I am pretty stuck. I would like to create a route based on directions. That is the easy part. Then do a search for a particular service, Gas Stations, Restaurants, Stores. I want the particular location along my route. My guess would be to create a buffer around my route (based on how far I would be willing to go off my route), and then clip the services that fall within the buffer. The issue with most searches is that when I do the search it gives me a radius search from my location or beginning location. I would like to find services along my route to help me choose the best location for a ce to stop.
I added a script, which is basically the Directions API. I like the way it is formatted with the options on the right. I am open to some ideas if anyone has any.
Thanks for your help.
Jason
RobertScheitlin__GISP
Jason,
   Do you have a service that would be used to represent the places youe are wanting to search for along your route (i.e Gas Stations, Restaurants, Stores)?
JasonSchelte
Robert, that is the part I am kind of trying to figure out. When I use the
Directions API for example I can get a few choices. Not sure if I can get a
specific list. Also is the buffer possible after the route is created? Do you
think that this is something that is possible?
Thanks for the help with this,
Jason
Jason,
   Sure you can get the routes geometry and then using the JS API you can buffer that route geometry. The issue would be having a mapservice that represents the desired stops for Gas Stations, etc.
JasonSchelte
Hmm, ok . Do you have any ideas on how we could accomplish that? Will it be
easier to go through ArcGIS online for something that. Or is there a way to do
the search after we have the buffer?
Jason
Jason,
   The only way I am familiar with is to have a map service that is a point feature for your Gas Stations, etc and use the QueryTask in the JS API to get the features of that map service that intersect the buffer.
JasonSchelte
Ok, that seems like it might work. Would I be able to get the info from the
point that was queried? For instance the address so I could re-input that in
the directions search. Are you able to create something like that? I am not
the strongest in writing Script.
Jason
Jason,
   I all boils down to you having a mapservice that represents your POIs (Gas, Food, etc.). If you find that then I might be able to find some time to provide you with some code example.
JasonSchelte
Would the ESRI query, work as a map service that could do the search?
Jason,
   I am not sure what you are referring to when you say "ESRI query"...
