Save Array of feature in documentdirectory
3710
11-10-2015 10:20 AM
SotlarStéphane
i have a NSMutableArray whit Feature and i want to write the NSMutableArray to my NSDocumentDirectory.
my code :
NSLog(@"ARRAY CARTE SCOLAIRE :%@", arrayCarteScolaire);
        NSArray *arrayCarteSauvegarde = [[NSArray alloc] initWithArray:arrayCarteScolaire];
        NSLog(@"ARRAY SAUVEGARDE :%@", arrayCarteSauvegarde);
        NSString* imageFilename = [NSString stringWithFormat:@"SAUVEGARDE CARTE %@", anneeChoisiTab];
        NSArray *paths = NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES);
        NSString *documentsDirectory = [paths objectAtIndex:0];
        NSString* imageFilePathname = [documentsDirectory stringByAppendingPathComponent:imageFilename];
        //on fait la verif pour voir s'il y a les images du bundle dans le DocumentDirectory
        if ([[NSFileManager defaultManager] fileExistsAtPath:imageFilePathname]) {
            NSLog(@"Fichier %@ déjà présent dans le dossier document - Voir pour la modification", imageFilename);
            //on efface et on copie
            NSError *error;
            BOOL success = [[NSFileManager defaultManager] removeItemAtPath:imageFilePathname error:&error];
            if (success) {
                NSLog(@"Le fichier %@ a bien été effacé", imageFilename);
                //UIAlertView *removeSuccessFulAlert=[[UIAlertView alloc]initWithTitle:@"Congratulation:" message:@"Successfully removed" delegate:self cancelButtonTitle:@"Close" otherButtonTitles:nil];
                //[removeSuccessFulAlert show];
            else
                NSLog(@"Could not delete file -:%@ ",[error localizedDescription]);
            //on copie le fichier
            NSError *error2;
            BOOL yes = [arrayCarteSauvegarde writeToFile:imageFilePathname atomically:YES];
            if (yes) {
                NSLog(@"Fichier %@ créer", imageFilename);
            else {
                NSLog(@"Could not create file -:%@ ",[error2 localizedDescription]);
        else {
            NSLog(@"Fichier %@ non présent dans le dossier document", imageFilename);
            //on va copier le fichier normalement
            NSError *error2;
            //BOOL yes = [NSKeyedArchiver archiveRootObject:arrayCarteSauvegarde toFile:imageFilePathname];
            if (yes) {
            else {
The file is not create in the document directory but no crash.
With this code :
else {
            NSError *error2;
            //BOOL yes = [arrayCarteSauvegarde writeToFile:imageFilePathname atomically:YES];
            if (yes) {
            else {
The app crash with this error :
2015-11-10 13:42:59.243 Ecoles Colleges 06 Antibes[211:11878] -[AGSGDBFeature encodeWithCoder:]: unrecognized selector sent to instance 0x1742a05a0
2015-11-10 13:42:59.245 Ecoles Colleges 06 Antibes[211:11878] *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[AGSGDBFeature encodeWithCoder:]: unrecognized selector sent to instance 0x1742a05a0'
Thanks for regards.
Stounfr
KristofferStenersen
Hi, the AGSGDBFeature cannot be saved to disk like this, as it does not subclass NSCoder.
I guess a reasonable question is why you want to persist the AGSGDBFeatures yourself - why not use the AGSGDBFeatureTable´s saveFeature?
SotlarStéphane
I want to copy AGSGDBFeature array in the device because i dont what modify the geodatabase.
When the user quit the app and reload it, i want that the app charge the geodatabase not modified and if the user want charge the modified Feature the app take the AGSGDBFeature.
Stounfr
SotlarStéphane
the how to :
for save
NSMutableArray *arrayCarteSauvegarde = [[NSMutableArray alloc] init];
        for (int i=0; i <[arrayCarteScolaire count]; i++) {
            AGSGDBFeature *feat = [arrayCarteScolaire objectAtIndex:i];
            NSDictionary *dicFeat = feat.allAttributes;
            NSDictionary *dicFeat2 = [dicFeat ags_encodeJSON];
            NSString *stringJSON = [dicFeat2 ags_JSONRepresentation];
            NSLog(@"STRING FEATURE : %@", stringJSON);
            [arrayCarteSauvegarde addObject:stringJSON];
            NSLog(@"%@", feat.geometry);
            //NSLog(@"JSON : %@", dicFeat2);
            //BOOL yes = [dataArray writeToFile:imageFilePathname atomically:YES];
            if (yes) {
            else {
for load
retourCarte = [NSArray arrayWithContentsOfFile:imageFilePathname];
for (int i=0; i<[retourCarte count]; i++) {
            //Bon on récupère les infos
            //NSDictionary *dicFeat = [retourCarte objectAtIndex:i];
            NSString *testJSON = [retourCarte objectAtIndex:i];
            NSLog(@"TEST JSON SHAPE : %@", testJSON);
            NSDictionary *dicFeat = [testJSON ags_JSONValue];
            NSLog(@"DICO JSON : %@", dicFeat);
            NSDictionary *geoDict = [dicFeat valueForKey:@"shape"];
            NSLog(@"SHAPE : %@", geoDict);
            AGSGeometry *geom = [[AGSGeometry alloc] initWithJSON:geoDict];
            NSLog(@"GEOMETRY : %@", geom);
            AGSMutablePolygon *testTest = [[AGSMutablePolygon alloc] initWithJSON:geoDict];
            NSLog(@"POLYGON : %@", testTest);
            /*NSDictionary *dicFeat2 = [testJSON ags_JSONValue];
            //NSLog(@"DIC JASON TRAITER : %@", dicFeat2);
            feat = [retourCarte objectAtIndex:i];
            //NSLog(@"FEAT : %@", feat);
            feat2.geometry = geom;
            //NSLog(@"FEAT 2 : %@", feat2);
            //[arrayCarteScolaire addObject:feat];*/
            //AGSGraphic *test = [[AGSGraphic alloc] initWithJSON:geoDict];
            AGSGraphic *test = [[AGSGraphic alloc] initWithGeometry:testTest symbol:nil attributes:dicFeat];
            NSLog(@"AGSGraphic = %@", test);
            [arrayCarteScolaire addObject:test];
Stounfr
