Runtime camera and bearing strange behaviour
2093
11-19-2015 06:57 AM
Durga_PrasadD
I find strange behavior with below implementation in Scene examples.The movement appears to have unexpected heading changes along the path.I have a set of points which are perfectly interpolated and are working fine in 2D animation.
public double generateBearing(double ox, double oy, double dx, double dy)
            double bearing = 0.0;
            double lon1 = ToRad(ox);
            double lat1 = ToRad(oy);
            double lon2 = ToRad(dx);
            double lat2 = ToRad(dy);
            double dLon = lon2 - lon1;
            double y = Math.Sin(dLon) * Math.Cos(lat2);
            double x = Math.Cos(lat1) * Math.Sin(lat2) - Math.Sin(lat1) * Math.Cos(lat2) * Math.Cos(dLon);
            double bRad = Math.Atan2(y, x);
            double tmpB = ToDegrees(bRad);
            //bearing =360.0-(tmpB+270.0)%360.0;
            bearing = tmpB;
            return bearing;
  private void CreateAnimationViewpoints()
            _animationViewpoints = new List<Camera>();
            Array.Reverse(x);
            Array.Reverse(y);
            heading = new double[nPointCount];
            for (int i = 0; i < nPointCount-1; i++)
                 heading=generateBearing(x, y, x[i + 1], y[i + 1]);
               // heading = getBearing(x, y, x[i + 1], y[i + 1]);
                 _animationViewpoints.Add(new Camera(new MapPoint(x, y, 50), heading, 70));
private async void MySceneView_SpatialReferenceChanged(object sender, System.EventArgs e)
            MySceneView.SpatialReferenceChanged -= MySceneView_SpatialReferenceChanged;
            try
                for (int i = 0; i < nPointCount; i++)
                    await MySceneView.SetViewAsync(_animationViewpoints, 1, false);
                // Set navigation in the order we want to animate the camera
            catch (Exception ex)
                MessageBox.Show("Error occured while navigating to the target viewpoint",
                    "An error occured");
                Debug.WriteLine(ex.ToString());
EricBader
Occasional Contributor III
Hi Durga,
In a previous life I was a .NET programmer, and this code looks very familiar!
Have you also posted this question to our .NET forum? This one here is specific to Android.
Thanks!
AnttiKajanus1
Could you provide a bit more details and/or full reproducible application to demonstrate the issue?
