Replace() string function isn't working within Field Calculator and arcpy
4918
12
11-23-2015 12:06 PM
EugeneDurshpek
New Contributor III
I'm trying to figure out what's wrong with my python syntax.
I have an attribute table with 4 fields containing paths to media files. I'm trying to convert the paths so that they behave more like hyperlinks on our network. The existing paths (added to the tables via 3rd party proprietary software) include network drive i.e. M:\GraniteXP\...
I'm trying to use find and replace to replace "M:\GraniteXP" with "\\vancouver.root.local\...\GraniteXP".
I can do this perfectly fine using field calculator in ArcMap as well as Model Builder. However, when I export the model to Python; the script runs (successfully), but the values are not updated. There is not error to tell me what's failing.
Here's a snippet from my script. I do have a MakeFeatureLayer prior to this snippet. (Note: this particular script is trying to change it back to the network drive pathing for testing purposes).
arcpy.SelectLayerByAttribute_management("lyrsdePipeInsp", "NEW_SELECTION", "Photo1 is not null")
arcpy.CalculateField_management("lyrsdePipeInsp", "Photo1", "Replace( [Photo1], \"\\\\vancouver.root.local\\cityapps\\GraniteXP\", \"M:\\GraniteXP\" )", "VB", "")
arcpy.SelectLayerByAttribute_management("lyrsdePipeInsp", "NEW_SELECTION", "Photo2 is not null")
    arcpy.CalculateField_management("lyrsdePipeInsp", "Photo2", "Replace( [Photo2],  \"\\\\vancouver.root.local\\cityapps\\GraniteXP\", \"M:\\GraniteXP\" )", "VB", "")
arcpy.SelectLayerByAttribute_management("lyrsdePipeInsp", "NEW_SELECTION", "Photo3 is not null")
arcpy.CalculateField_management("lyrsdePipeInsp", "Photo3", "Replace( [Photo3], \"\\\\vancouver.root.local\\cityapps\\GraniteXP\", \"M:\\GraniteXP\" )", "VB", "")
arcpy.SelectLayerByAttribute_management("lyrsdePipeInsp", "NEW_SELECTION", "Video is not null")
arcpy.CalculateField_management("lyrsdePipeInsp", "Video", "Replace( [Video], \"\\\\vancouver.root.local\\cityapps\\GraniteXP\", \"M:\\GraniteXP\" )", "VB", "")
Thanks!
Eugene Durshpek
Luke_Pinner
MVP Regular Contributor
You've got your find string and replacement string in the wrong order.
Try:
arcpy.CalculateField_management("lyrsdePipeInsp", "Photo1", r'Replace( [Photo1],"M:", "\\vancouver.root.local")',"VB")
Or:
arcpy.CalculateField_management("lyrsdePipeInsp", "Photo1", r"!Photo1!.replace('M:', r'\\vancouver.root.local')", "PYTHON_9.3")
DanPatterson_Retired
a pain with the double slash replacement, you could try replacement with "/"
>>> a = "c:\\path\\subpath\\file.tiff"
>>> b = a.replace("\\","/")
>>> b
'c:/path/subpath/file.tiff'
EugeneDurshpek
New Contributor III
Thanks Dan. I will combine your suggestion with Luke's suggestion (below) and will hopefully have best of both worlds.
Eugene D.
LukeSturtevant
Occasional Contributor III
It is a lot faster and easier to code this type of processing with an update cursor​.
something like this would work for the code example you gave:
import arcpy
fc = #the path to your feature class
with arcpy.da.UpdateCursor(fc,["Photo1","Photo2","Photo3","Video"]) as update:
     for row in update:
          if row[0] is not None:
                row[0] = row[0].replace("\\vancouver.root.local\\cityapps\\GraniteXP", "M:\\GraniteXP")
         if row[1] is not None:
                row[1] = row[1].replace("\\vancouver.root.local\\cityapps\\GraniteXP", "M:\\GraniteXP")
         if row[2] is not None:
                row[2] = row[2].replace("\\vancouver.root.local\\cityapps\\GraniteXP", "M:\\GraniteXP")
         if row[3] is not None:
                row[3] = row[3].replace("\\vancouver.root.local\\cityapps\\GraniteXP", "M:\\GraniteXP")
           update.updateRow(row)
EugeneDurshpek
New Contributor III
Thank you Luke, I will give this a try. I'm a novice and wasn't sure how to apply the update cursor function to my scenario. I appreciate your quick response.
Eugene D.
EugeneDurshpek
New Contributor III
I am testing this within a session of ArcMap and am getting Runtime Error: Insufficient permissions to edit the feature class [STATE_ID = 207215] which is odd because I can edit and save outside of python.
LukeSturtevant
Are you working from an SDE geodatabase? In either case when I see this error I find that opening a da Editor​ helps:
import arcpy
workspace = # path to you workspace
fc = # the path to your feature class
with arcpy.da.Editor(workspace) as edit:
           for row in update:
EugeneDurshpek
New Contributor III
Thank you Luke;
Yes, I am editing an SDE feature class. I have updated my script (see below) but am now getting a "RuntimeError: cannot open workspace"; I will clean it up once I can get it to work.
import arcpy
workspace = "M:/GIS/Support_Files/DataConnectionsADMIN/SewerVan_NT_SQLGIS1.sde/SewerVan.VANSEWER.SwrPipeInspected"
fc = "SewerVan.VANSEWER.SwrPipeInspected"
        for row in update:
                    row[0] = row[0].replace("//vancouver.root.local/cityapps/GraniteXP", "M:/GraniteXP")
                    row[1] = row[1].replace("//vancouver.root.local/cityapps/GraniteXP", "M:/GraniteXP")
                    row[2] = row[2].replace("//vancouver.root.local/cityapps/GraniteXP", "M:/GraniteXP")
                row[3] = row[3].replace("//vancouver.root.local/cityapps/GraniteXP", "M:/GraniteXP")
LukeSturtevant
I'm not sure if there is an easy way to use the cursors in an ArcSDE geodatabase environment. You could look at this forum here​ that shows a work around. If you cannot get that figured out you may want to attempt  Luke Pinner's suggestion below.
WesMiller
Regular Contributor III
Not by chance a 64-bit? see below
Caution:
Field calculations with a VB Expression type are not supported on 64-bit products, including ArcGIS Pro, ArcGIS for DesktopBackground Geoprocessing (64-bit) and ArcGIS for Server. To successfully use Calculate Field in these products, expressions should be converted to Python, or in the case of Background Geoprocessing (64-bit), background processing can alternatively be disabled.
Calculate Field—Help | ArcGIS for Desktop
