Distance measurement is wrong
2063
11-24-2015 07:32 AM
fuliaoli
New Contributor III
I'm using ESRI base maps and add local UTM layers in my map app. From I can read, UTM layers would be magically re-projected into ESRI's web mercator. All UTM layers shows ok, but when I use Draw tool to measure the distance between the two borders of a Township, Range and Section(1 mile) I get 1.4miles. Does the distance calculation use a different projection?
Does anyone have some ideas to solve the problem?  Please help.
Thanks in advance,
li
DanPatterson_Retired
check the data frame and file coordinate systems from their properties... there are 1.6 km per mile so 1.4 isn't close
fuliaoli
New Contributor III
Dan,
Thanks a lot for your quick reply. I checked some samples again and tried by setting geodesic=true, which solved the calculation problem.
Have a happy Thanksgiving!
Regards,
li
