Hi everybody,
I am trying to make an interpolation for sediment magnitude in a reservoir. I have imported the file with my points, which has information about, X,Y, and sediment magnitude in each. I have also created a raster file for the slope of the bottom of the reservoir. What I want to do is to create a interpolation raster in which the slope of the reservoirs bottom should be taken in consideration. Does anybody know if I can make it in ArcGis without using Python or any other programming language?
Thank you
Hi , i think you need to do the interpolation first then with raster calculator you create another raster but the slope of the reservoirs is taken in consideration ; like you need to give weight for the raster interpolation and the slope raster.
I am not so sure but you can try it.
Thank you for your reply! I'll try it and I hope it works!
