I am trying to direct connect to a table on an MS SQLSERVER 2008 slice. I would like to create an x,y event layer to display on a web map using the JavaScript API. I am, however, receiving an error message when I attempt to open the table:
Error reading OID from table. Reading rows has been stopped. Check that the datasource is valid. OID mapped column has null value. The operation is not supported by this implementation. |
From what I can tell, it's an issue with including the PK on the table:
Here's the data type:
idnum (PK, FK, numeric(18,0), not null)
I am unable to change structure - is there any way to work around this? My dev environment is using ArcGIS Server 10.2 - my production environment is 10.3 if this is a bug of some sorts in 10.2.
Any help is appreciated! Thanks!
