Mobile Backhaul Optimisation
3764
13
12-29-2015 04:45 PM
DavidBrown3
New Contributor III
Hi
I am trialing ArcGIS Pro / Desktop as part of the 60-day trial and have downloaded PRO 10.31 DESKTOP
I want to test the Backhaul Optimisation application within ArcGIS to test replacing Microwave Links with Fibre backhaul.
Questions -
Where is BackhaulOptimisation.mxd?
How do I activate the Network Analyst Extension?
Do I need the licensed paid version of the Network Analyst Extension to make the Backhaul Optimisation work?
Where do I download Network Analyst Extension from?
Thanks / David
DanPatterson_Retired
I don't know if the trial versions come with all the extensions...but if they do, you probably have them installed.  To toggle on an extension, you need to go to the Customize/Extensions menu and toggle on the Network Analyst.  As for the project (aka *.mxd) no clue, if it is a tutorial you might find some reference to it here
About the ArcGIS Network Analyst extension tutorial—Help | ArcGIS for Desktop
general help for NA is found here
What is the ArcGIS Network Analyst extension?—Help | ArcGIS for Desktop
DavidBrown3
New Contributor III
I will review this.
Was this marked assumed answered by you David?
DavidBrown3
New Contributor III
Yes it was - am I not supposed to do that?
never mind...its ok
DavidBrown3
New Contributor III
Hi - when I believe a question is answered how do I put a green tick beside
the thread? To me its not clear and I do not use threaded forums routinely
enough to know the correct thing.
SpatialNinja
David,
You can download the backhaul model and learn about the requirements here.
Backhaul Optimization | ArcGIS for Telecommunications
And you can get started setting about network analyst by following this guide:
Overview - Backhaul Optimization | ArcGIS for Telecommunications
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
DavidBrown3
New Contributor III
Hi. It does not say whether it works with Street map OSM.
SpatialNinja
No it does not, but it will work with the street data & maps that are included with an ArcGIS for Desktop subscription.
