Add XY Coordinates Automatically for a New Point,
4208
10
01-03-2016 03:08 AM
MajdoleenO_A__Awadallah
Occasional Contributor III
I’ve used “Calculate Geometry” and “Add XY coordinate” to calculate the XY coordinates, but when adding a new point, both the X and Y fields are empty for the new point.
I am looking for a way to calculate the XY coordinates automatically when adding a new point.
Thank you in advance.
Best,
Majdoleen
DanPatterson_Retired
why not wait and do it after... it will save you some time Add XY Coordinates—Help | ArcGIS for Desktop
Hi Dan,
Our Data is updating everyday! we couldn't leave it without coordinates.
Best,
Majdoleen
WesMiller
Regular Contributor III
You could set a script to populate XY fields every day or night.
I looking for such a way like the area or the length field.
Thank you,
Best,
Majdoleen
There is such a tool in arctoolbox for those that like things automagically done
... Add Geometry Attributes—Help | ArcGIS for Desktop
Thank you Dan, As I mentioned in my first post, I used "calculate Geometry" to calculate the X, Y Coordinates, but when adding new point the coordinate fields are empty!! this is my main point, I want these fields to be fill automatically.
Best,
Majdoleen
AhmadSALEH1
Hi majdoleen,
You can host your data in SQL server (mdf) then you can write SQL trigger to calculate X,Y values, this trigger will run automatically when you update your data.
shan_sarkar
Majdoleen,
The same can be done with Oracle as well if you prefer to use it.
~Shan
~Shan
GideonDalrymple
New Contributor III
Hey Majdoleen Awadallah. Did you get that accomplished? I am looking to achieve the same result.
