How to show data from geoserver in ESRI Geoportal Map Viewer
5158
01-13-2016 11:26 PM
hamarisikyarto
Hi, I'm using ESRI Geoportal 1.2.5 to develop a geoportal and I have a problem to show data in Map Viewer which harvest in Geoserver. The notification say that have problem with EPSG:102100 and in Geoserver I store it in EPSG:4326. How must I do to I resolve it?
Tags (3)
MartenHogeweg
when working with OGC WMS services (such as those provided by GeoServer, but also available in ArcGIS for Server), it is preferred to use a basemap that is in EPSG:4326 projection. this is because that is the only required projection to be supported by WMS services. Anything else (such as EPSG:102100) and you may run into WMS services that cannot reproject (which is done server-side).
