i am using AGSFindParameters, service to search Asset on MAP as below:
for (NSArray *arrCurrentAsset in m_arrAssetDetails)
self.m_findParams = [[[AGSFindParameters alloc]init] autorelease];
self.m_findParams.contains = NO;
self.m_findParams.layerIds = arrLayerIDs;
self.m_findParams.outSpatialReference = self.m_mapView.spatialReference;
self.m_findParams.returnGeometry = TRUE;
self.m_findParams.searchFields = arrUniqueNames;
self.m_findParams.searchText = [arrCurrentAsset objectAtIndex:2];
//execute find task
[self.m_findTask executeWithParameters:self.m_findParams];
there are around 350 elements in m_arrAssetDetails, so above query executes with individual search parameter those many times....
Q. 1) is there any better way which i can find all asset with one query?
-(void)findTask:(AGSFindTask *)findTask operation:(NSOperation *)op didExecuteWithFindResults:(NSArray *)results {
delegates get called for around 50 Assets then
-(void)findTask:(AGSFindTask *)findTask operation:(NSOperation *)op didFailWithError:(NSError *)error {
get called till 350 calls.... error i get is:
NSLocalizedDescription=The request timed out., _kCFStreamErrorDomainKey=4, NSUnderlyingError=0x7d45a0e0 {Error Domain=kCFErrorDomainCFNetwork Code=-1001 "(null)" UserInfo={_kCFStreamErrorDomainKey=4, _kCFStreamErrorCodeKey=-2102}
this happens for only one client, rest client's with different server works fine.
Q. 2) what is the possible reason i am getting error , is from server side....how to fix it from server side or app side..?
Plz answer its urgent....
