ArcGIS Earth Performance Issues
5428
11
01-26-2016 03:30 PM
GavinMayeda
Occasional Contributor II
I searched through the other posts but didn't see anyone having performance issues with ArcGIS Earth.  Like many others, I am delving in to ArcGIS Earth due to the changes in Google Earth Pro.
I am having some serious performance issues after opening ArcGIS Earth.  The initial screen will load completely black, and then the program will freeze for up to 5 minutes.  Then a view of the earth will appear and freeze again with a view of the African continent. After another few minutes the earth view will rotate to the Atlantic Ocean.
From what I can tell, ArcGIS Earth is hogging damn near all of my available RAM. (See attached capture)  At the time I captured the Task Manager screen the only things that I had open were Outlook, IE, Windows Explorer and ArcGIS Earth.
After the initial install I was able to load a shapefile, but since then it is having the issues described above.  How can I improve the performance of ArcGIS Earth?
Dell OptiPlex 9010
Intel(R) Core(TM) i7-3770 CPU @ 3.40 GHz
8.0 GB RAM
Windows 7 Professional 64-bit OS
AMD Radeon HD 7570
Dual Dell U2414H Monitors
PROBERT68
This was from this morning I received from an email and thought you might want to read from a blogger.
15 Minutes With ArcGIS Earth 1.0 | SoCalGIS.org
DanPatterson_Retired
I have shared this to ArcGIS Earth
GavinMayeda
Thank you Dan,
I didn't see that as an option!
no problem on posting with GIS, and the Share option is over to the right...but I think it only becomes available when you post...then share...can't remember... use the @symbol to bring up peoples names and/or places or spaces.
GavinMayeda
The problem was with the shapefile that I loaded.  This was a relatively small shapefile at less than 5Mb (a 43 lot subdivision).  This does bother me a bit, but after publishing as a map service it is much better.
I do have a question, are there any tools such as Identify already in ArcGIS Earth?
ArcGIS Earth
JasmineDu
Hi Gavin,
The issue is logged and the team is working on improving performance. In V1.2 UC release, feature identify will be supported.
Best,
Jasmine
AidaAfrooz
New Contributor III
I have a similar problem. ArcGIS Earth doesn't display anything and freeze several times. Even when I upload a map from ArcGIS online, it doesn't display anything.
Any suggestions?
ArcGIS Earth display issue
what about the system requirements?
ArcGIS Earth | ArcGIS
AidaAfrooz
New Contributor III
Hi Dan,
Sorry I forgot to add them:
Windows 7
