Fatal error when creating a thematic world map
2145
01-29-2016 10:39 AM
GeoffreyZhang
I am seeking helps in creating thematic maps. I wanted to create a thematic map for selected countries by following the sample code in ArcGIS JAVA runtime SDK (RenderingApp.java). Basically, what I would like to achieve is to fill a color for a country area. The program runs okay for countries with a small/medium area like Peru, Belize, Bermuda. But for countries like Canada, a fatal error occurs every time:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007feeac9c3f9, pid=7612, tid=7536
# JRE version: Java(TM) SE Runtime Environment (8.0_65-b17) (build 1.8.0_65-b17)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.65-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [msvcr120.dll+0x3c3f9]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Any suggestion on how to fix this is greatly appreciated!
BatbayarBazarragchaa
New Contributor III
Did you increase your JVM heap size something like following?
-J-Xms128m -J-Xmx768m
