How to draw on the map
2521
7
02-01-2016 05:32 AM
by Anonymous User
Not applicable
Is there an alternative to using the Draw toolbar? Will the draw toolbar be in 4.0 final?
Tags (1)
KristianEkenes
The plan is to have a rudimentary version of Draw in 4.0 final.
KristianEkenes
by Anonymous User
Not applicable
Thank you.  And what about Editor? Will there also be some form of that as well?
KristianEkenes
No Editor.
MiriamBrockmann
Rudimentary means an access to the toolbar like it is now?
KristianEkenes
Not sure if you're referring to 3.15 or 4.0 beta 3 when you say "now", but the plan is to have basic draw capabilities like drawing a line, point, polygon. It won't look the same as 3.15.
MiriamBrockmann
Hi Kristian!
Thanks for your answer!
We are using the 3.15 Api by now and i have programmed a tool which allows the user
to select what Geometry he wants to draw, the Color of the Outlines/Filling, Linewidth/style etc.
and i want to make sure if it will work further on.
Then this should work in 4.0, maybe with some changes i think.
Regards, Miriam
JW1
@Kristian Ekenes
what is the latest plan? I cannot find Draw even in version 4.1 final.
