LATITUDE AND LONGITUDE RESULT ON MAP BY USER
2712
7
02-03-2016 08:16 PM
ADITIROY
New Contributor III
HELLO GUYS,CAN YOU PLEASE HELP ME.  I WANT TO SHOW THE RESULT OF LATITUDE AND LONGITUDE ON THE MAP AS POINT AND LAT AND LONG WILL BE FEED BY THE USER IN ARCGIS JAVASCRIPT.
ADITIROY
New Contributor III
Dear Robert,
Thank you for your help.
Aditi
DanPatterson_Retired
so what have you read?  what have you tried? a very open question or are you looking for a pre-done solution?
ADITIROY
New Contributor III
Hello Sir,
Thank you for the prompt reply. I am new to ArcGIS JavaScript. I want some help in doing the coding and want to see some pre done solution on this topic. Basically I want to search the location of the point on the earth when  I feed latitude and longitude from an user point of view . It will something similar to geocode  example where instead of inputting the location or address the user will feed latitude and longitude.
Thanks Again,
Aditi
MiriamBrockmann
Good Morning!
I would have a close look at esris map.centerAt(mapPoint)
Here's the Hyperlink to it. Normaly that's all you need to zoom to a Point on a Map.
Map | API Reference | ArcGIS API for JavaScript
Regards, Miriam
RobertScheitlin__GISP
Adita,
   Sure Tim Witt has a widget out there just for this:
http://jsfiddle.net/timw1984/ahnmv8gy/embedded/result/
ADITIROY
New Contributor III
Dear Robert,
Aditi
ADITIROY
New Contributor III
Hi Everyone,
I have one more question, the point plotted on the map and I want to directly do a buffer on the point on click.
Aditi
Aditi,
   You will have to add code to the function where the graphic is added to the map.Look at the Geometry Engine buffer method:
esri/geometry/geometryEngine | API Reference | ArcGIS API for JavaScript | Buffer
Also if your original question has been answered then make sure you mark this thread as the correct answer.
