Help with Run time error 91
3997
02-04-2016 10:51 AM
EthanDunker
I am trying to create a button for ArcMap and I get Run time error 91 object variable or with block variable not set. I know the problem is one line 84 & 86. If I take them out the code runs, but it returns all my locations from the table. Also if you change the SEARCH_THRESHHOLD to 10000000, the code run with line 84 and 86 in there, but the same thing happens, it returns all my locations.  I have the same code in another ArcMap and it works just fine. So I don't know what the problem is. Is there a setting I need to change in ArcMap itself? I am using ArcMap 10.3.1.
Here is the code:
Option Explicit
Const dbpath = "C:\Users\edunker\Documents\"
Const dbname = "WorkOrderDatabase.accdb"
'Const coord_file = "currcoords.dat"
'Const signshp_path = "s:\Highway\Signs\signdb\"
'Const signshp_file = "signsall"
Const GPS_BAUD = 4800
Const GPS_PORT = 1
Const SEARCH_THRESHHOLD = 10
Private Sub EditWorkOrderData_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
Dim pMxDoc As IMxDocument
    Dim pGPSPoint As IPoint
    Dim pCursorPoint As IPoint
    Set pCursorPoint = New Point
    Dim pLocationFeat As IFeature
    Dim pSignFClass As IFeatureClass
    Set pMxDoc = ThisDocument
    pCursorPoint.x = pMxDoc.CurrentLocation.x
    pCursorPoint.y = pMxDoc.CurrentLocation.y
    Dim pGeometry As IGeometry
    Set pGeometry = pCursorPoint
    Dim pTopoOperator As ITopologicalOperator
    Set pTopoOperator = pCursorPoint
    Dim dblSearchDistance As Double
    dblSearchDistance = SEARCH_THRESHHOLD
    Dim pBufferGeometry As IGeometry
    Set pBufferGeometry = pTopoOperator.Buffer(dblSearchDistance)
    Set pLocationFeat = GetSelectedLocation(pBufferGeometry)
    If pLocationFeat Is Nothing Then Exit Sub
    Shell "c:\Program Files (x86)\Microsoft Office\Office14\msaccess.exe " & dbpath & dbname & " /cmd Locationedit=" & pLocationFeat.Value(pLocationFeat.Fields.FindField("LocationID")), vbMaximizedFocus
End Sub
Public Function GetSelectedLocation(pGeom As IGeometry) As IFeature
    Dim pMap As IMap
    Set pMap = pMxDoc.FocusMap
    Dim strRoadNumber As String
    Dim strLocationType As String
    Dim strLocationID As String
    'Dim strOrientation As String
    Dim i As Long
    Dim pFLayer As IFeatureLayer
    Dim pFClass As IFeatureClass
    Dim pID As New esriSystem.UID ' New esriCore.UID
    Dim pAllFLayers As IEnumLayer
    pID.Value = "{E156D7E5-22AF-11D3-9F99-00C04F6BC78E}"
    Set pAllFLayers = pMap.Layers(, True)
    Set pFLayer = pAllFLayers.Next
    Do Until pFLayer Is Nothing
        If pFLayer.Name = "LocationData" Then Exit Do
    Loop
    Set pFClass = pFLayer.FeatureClass
    Dim pScratchWorkspace As IWorkspace
    Dim pScratchWorkspaceFactory As IScratchWorkspaceFactory
    Set pScratchWorkspaceFactory = New ScratchWorkspaceFactory
    Set pScratchWorkspace = pScratchWorkspaceFactory.DefaultScratchWorkspace
    Dim pSpatialFilter As ISpatialFilter
    Set pSpatialFilter = New SpatialFilter
    'Set pSpatialFilter.Geometry = pGeom
    'pSpatialFilter.GeometryField = "SHAPE"
    'pSpatialFilter.SpatialRel = esriSpatialRelContains
    Dim pFeatureCursor As IFeatureCursor
    Set pFeatureCursor = pFClass.Search(pSpatialFilter, False)
    Dim pFeat As IFeature
    Dim pTempFeat As IFeature
    Set pFeat = pFeatureCursor.NextFeature
    strRoadNumber = pFeat.Value(pFeat.Table.FindField("RoadNumber"))
    strLocationType = pFeat.Value(pFeat.Table.FindField("LocationType"))
    strLocationID = pFeat.Value(pFeat.Table.FindField("LocationID"))
    'strOrientation = pFeat.Value(pFeat.Table.FindField("ORIENTATIO"))
    If pFeat Is Nothing Then
        MsgBox "You must select a Location", vbCritical
        Set GetSelectedLocation = Nothing
        Exit Function
    End If
    If pFeat.Fields.FindField("LocationID") = -1 Then
        MsgBox "You must select a sign to position first", vbCritical
        Exit Function
    End If
    Set pTempFeat = pFeatureCursor.NextFeature
    If Not pTempFeat Is Nothing Then
        Set pFeat = pTempFeat
        Load frmMultiplePoint
        frmMultiplePoint.lstLocation.Clear
        frmMultiplePoint.lstLocation.AddItem
        frmMultiplePoint.lstLocation.List(0, 0) = strRoadNumber
        frmMultiplePoint.lstLocation.List(0, 1) = strLocationType
        frmMultiplePoint.lstLocation.List(0, 2) = strLocationID
        'frmMultiplePoint.lstLocation.List(0, 3) = strOrientation
        Do While Not pFeat Is Nothing
            frmMultiplePoint.lstLocation.List(frmMultiplePoint.lstLocation.ListCount - 1, 0) = strRoadNumber
            frmMultiplePoint.lstLocation.List(frmMultiplePoint.lstLocation.ListCount - 1, 1) = strLocationType
            frmMultiplePoint.lstLocation.List(frmMultiplePoint.lstLocation.ListCount - 1, 2) = strLocationID
            'frmMultiplePoint.lstSigns.List(frmMultiplePoint.lstSigns.ListCount - 1, 3) = strOrientation
        Loop
        frmMultiplePoint.Show
        If frmMultiplePoint.Tag = "OK" Then
            For i = 0 To frmMultiplePoint.lstLocation.ListIndex
            MsgBox "Selecting Location with ID: " & pFeat.Value(pFeat.Table.FindField("LocationID")), vbInformation, "Success"
        Else 'frmMultiplePoint.Tag = "CANCEL"
            Exit Function
        End If
    End If
    Set GetSelectedLocation = pFeat
End Function
Tags (1)
deleted-user-bTT1-4SKF1c0
Hi Ethan,
Interesting question.
Which lines are 84 and 86?
Leo.
EthanDunker
Line 84 is:
and Line 86 is:
curtvprice
MVP Esteemed Contributor
Option Explicit
Const GPS_PORT = 1
End Sub
    Dim pMap As IMap
    Dim i As Long
    Loop
    Set pSpatialFilter.Geometry = pGeom                ' <------
    pSpatialFilter.GeometryField = "SHAPE"             ' <------ fail, error 91
    pSpatialFilter.SpatialRel = esriSpatialRelContains ' <------
        Exit Function
    End If
        Exit Function
    End If
        Loop
            Exit Function
        End If
    End If
End Function
Posting Code blocks in the new GeoNet
EthanDunker
Okay so the line switched because of extra line spaces its now line 93 and line 95.
