Using Python to select records by date field
10319
02-05-2016 10:08 AM
RachelAlbritton
Occasional Contributor III
I am trying to write a python script to select records created within the past 7 hours (date field - database time).
I've written a script that calculates the time 7 hours prior to the current time:
(Python 2.7.8)
start_time= datetime.timedelta(hours = 7)
end_time = datetime.datetime.now()
report_time = end_time-start_time #this is the time that gets used to filter records
Then I wanted to use the "report_time" variable to select the relevant records in a table view but I'm getting an invalid expression error. I'm not sure if the error is because the SQL expression is incorrect (which is possible) OR if its because there's formatting differences in the date/time structure. For example if I run the above expressions in python shell, the datetime returned is 2016-02-05 03:49:11.322000
The date field in the SDE table is formatted like this:  2/4/2016 2:18:25 PM. I wondering if this matters and if so, how to deal with it.
Here's my current SQL script:
SQL = '"created_date" <= report_time' #this returns an expression error
#SQL = "'created_date' <= report_time" #also tried this - expression error
#SQL = 'created_date'<= report_time # returns error: TypeError: can't compare datetime.datetime to str
print SQL
arcpy.SelectLayerByAttribute_management(ViewTable,"NEW_SELECTION", SQL)
RachelAlbritton
I figured it out. I opened out the select by attribute tool in arcmap, selected the 'date_created' field and then clicked on get records so I could see how the date-time format looked in the SQL calculator compared to how it looked in the table. They were different! Using this information I reconstructed my where clause:
#Turn ReportsTable into a View Table
arcpy.MakeTableView_management(ReportsTable, ViewTable)
# Get start and end times for report
start_time= datetime.timedelta(hours = 24)
#find all records that are later than or = to report_time
SQL = "created_date >="+ "'"+report_time.strftime('%Y-%m-%d %H:%M:%S')+"'"
print SQL
Note that the quotes before report_time are double- single - double quotes " ' "
Same with the very last set of quotes
DanPatterson_Retired
DarrenWiens2
MVP Honored Contributor
You need to get your query into the format: "Datefield" = date 'yyyy-mm-dd hh:mm:ss'
Use strftime() to format the datetime object.
The following works for a shapefile, which doesn't support time, but you can generally use this pattern:
>>> report_time = datetime.datetime.now()
... SQL = '"OBSDATE" <= date \'' + str(report_time.strftime('%Y-%M-%d')) + '\''
... print SQL
... arcpy.SelectLayerByAttribute_management("MY_LAYER","NEW_SELECTION", SQL)
"OBSDATE" <= date '2016-05-26'
RachelAlbritton
I used the reference provided to format the time to match the time format in the ArcSDE table.
report_time.strftime('%m/%d/%Y %I:%M:%S %p')
Its really import that I'm able to query against the time, not just the date or I can't grab only relevant reocrds.
By itself, this prints out the correct format:
02/04/2016 12:03:28 PM
but when I take that and plug it into a where clause I'm still having issues.
SQL = '"created_date"<='+ str(report_time.strftime('%m/%d/%Y %I:%M:%S %p'))
print SQL
Returns:
ExecuteError: ERROR 000358: Invalid expression
Failed to execute (SelectLayerByAttribute).
I also tried it this way (so the attribute is in single quotes) and still get the same error:
SQL = "'created_date'<= "+ str(report_time.strftime('%m/%d/%Y %I:%M:%S %p'))
RachelAlbritton
print SQL
