Collector failing creating offline map / replica with SOI on feature service
7434
7
02-04-2016 04:21 PM
FraserHand
Occasional Contributor III
Hi there,
I have come across an issue where Collector fails to create a replica for an offline map where the map service / feature service has an SOI enabled. This has been tested with a vanilla empty SOI from the .NET template. The create replica and job calls appear to pass through fine but when the relica is actually created (and it does get created) and the call is passed back to the Sync tools an internal error occurs.
What is returned to Collector is
example call: http://some server/arcgis/rest/services/map/FeatureServer/jobs/j39b3b26056d047609d3dbc...
{"resultUrl":"","replicaName":"","submissionTime":1454618828000,"lastUpdatedTime":1454619008000,"status":"Failed","error":{"code":500,"description":"Failed to create replica."}}
Downloading of the map onto device then fails.
The logs detail the following - it looks like a bug but are we able to code around this in the SOI?
Fraser
FINE
String request successfully processed. Response size is 378 characters.
System/SyncTools.GPServer
  1. GPServer.ExecuteJob.CreateFeatureServiceReplica
VERBOSE
Save job j52cc43e658e140bc8116b166a26eb8e7 message type Binary message size 378
  1. GPServerSync.Save.CreateFeatureServiceReplica
VERBOSE
Save job j52cc43e658e140bc8116b166a26eb8e7 message type Binary message size 552
SEVERE
Error executing tool. CreateFeatureServiceReplica Job ID: j52cc43e658e140bc8116b166a26eb8e7 : ErrorMsg@SyncGPService:{"code":500,"description":"Failed to create replica."} Failed to execute (Create Feature Service Replica).
  1. GPServerSync.CheckMessages
VERBOSE
Execute job j52cc43e658e140bc8116b166a26eb8e7
  1. GPServerSync.Execute.CreateFeatureServiceReplica
FINE
REST request successfully processed. Response size is 103 characters.
/createReplica
FINE
  1. GraphicFeatureServer.HandleREST_CreateReplicaOperation has completed.
FINE
Removing GeoTransformation: from GeoTransformation Defaults.
SetupGeoTransformation::~SetupGeoTransformation
SEVERE
An error occurred.
GraphicFeatureServer::CreateSyncReplicaREST
FINE
  1. GeoDataServer.CreateSyncReplica has completed for Replica: Ags_Fs
DEBUG
VirtualOutputDirectory: /rest/directories/arcgisoutput/SOI_MapServer/, CanUseUrls: 0, InServer: 1
  1. GeoDataServer.SetupResultGDSData
DEBUG
Time (ms): 59 (/arcgis/rest/services/SOI/FeatureServer/jobs/j52cc43e658e140bc8116b166a26eb8e7)
Rest
DEBUG
Got Response: (SOI, MapServer)
Rest
DEBUG
Posting response from worker thread.
  1. SOI.MapServer
FINE
REST request successfully processed. Response size is 117 characters.
  1. SOI.MapServer
DEBUG
End GraphicFeatureServer.HandleREST_JobResource method.
  1. SOI.MapServer
  2. GraphicFeatureServer.HandleREST_JobResource
INFO
Request for the service 'System/SyncTools.GPServer' processed successfully. Response sent to the user '22a48e75-2607-4687-998f-27274f871f76'.
Soap
DEBUG
DEBUG
Request received in worker thread.
FINE
Binary request successfully processed. Response size is 1003 bytes.
  1. GPServer.GetJobInputValues
FINE
Binary request received. Request size is 375 bytes.
DEBUG
Waiting for response from worker thread - System/SyncTools.GPServer.
DEBUG
Sending request to worker thread - System/SyncTools.GPServer.
DEBUG
Delegating request to GPServer - System/SyncTools.GPServer.
nicogis
MVP Frequent Contributor
in debug soi have you errors ?
FraserHand
There are no errors in the SOI - using the vanilla template the SOI just hands straight off to the appropriate delegate as a TRESTHandler - which in this case is the feature server. The error seems to happen in the server code following that pass off. Unless the SOI is handing it to the wrong delegate (but it looks ok?)
Ta
Fraser
StefanHendren
We have the same issue - A createReplica Request fails when an interceptor is enabled. Errors seen are the same as above.
We have also tried disabling the interceptor to download the map and then re-enabling it to sync. However when syncing it fails (Error Log for Sync failure shown below).
nicogis
Now 10.4 is available in myEsri. Have you a chance try with ags 10.4 ?
StefanHendren
Yes we have tried 10.4 pre-release and we have the same issue.
JakubŠilhavý
we have the same issue. Collector fails to download map if the service is extended by SOI. We are using 10.4 enviroment.
SEVERE21. 3. 2016 10:32:47Error executing tool. CreateFeatureServiceReplica
Job ID: j5de19757bc734b779ab307c371d9f08a :
Jakub
pheede-esri
All, this has been logged as BUG-000094193. Please contact Esri Technical Support for options on how to proceed.
