arcgis 10.3 cannot connect to license manager
6160
02-05-2016 06:54 AM
LahmerBelkacem
Hi All !
I have an arcgis 10.3 version i install it and it's work perfectly , but today won't work an i get this error:
and i think (i am not sure ) that esru cityengine is my problem because i install a trial copy from esri.com
and her is the lmgrd9.log file
15:41:23 (lmgrd) -----------------------------------------------
15:41:23 (lmgrd)   Please Note:
15:41:23 (lmgrd)
15:41:23 (lmgrd)   This log is intended for debug purposes only.
15:41:23 (lmgrd)   In order to capture accurate license
15:41:23 (lmgrd)   usage data into an organized repository,
15:41:23 (lmgrd)   please enable report logging. Use Flexera Software LLC's
15:41:23 (lmgrd)   software license administration  solution,
15:41:23 (lmgrd)   FlexNet Manager, to  readily gain visibility
15:41:23 (lmgrd)   into license usage data and to create
15:41:23 (lmgrd)   insightful reports on critical information like
15:41:23 (lmgrd)   license availability and usage. FlexNet Manager
15:41:23 (lmgrd)   can be fully automated to run these reports on
15:41:23 (lmgrd)   schedule and can be used to track license
15:41:23 (lmgrd)   servers and usage across a heterogeneous
15:41:23 (lmgrd)   network of servers including Windows NT, Linux
15:41:23 (lmgrd)   and UNIX. Contact Flexera Software LLC at
15:41:23 (lmgrd)   www.flexerasoftware.com for more details on how to
15:41:23 (lmgrd)   obtain an evaluation copy of FlexNet Manager
15:41:23 (lmgrd)   for your enterprise.
15:41:23 (lmgrd)
15:41:23 (lmgrd)
15:41:23 (lmgrd)
15:41:23 (lmgrd) Server's System Date and Time: Fri Feb 05 2016 15:41:23 W. Central Africa Standard Time
15:41:23 (lmgrd) pid 8040
15:41:23 (lmgrd) SLOG: Summary LOG statistics is enabled.
15:41:23 (lmgrd) Done rereading
15:41:23 (lmgrd) FlexNet Licensing (v11.12.1.2 build 152538 i86_n3) started on BELKACEM (IBM PC) (2/5/2016)
15:41:23 (lmgrd) Copyright (c) 1988-2014 Flexera Software LLC. All Rights Reserved.
15:41:23 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
15:41:23 (lmgrd) lmdown/lmreread only allowed on this machine
15:41:23 (lmgrd) License file(s): C:\Program Files (x86)\ArcGIS\License10.3\bin\service.txt
15:41:23 (lmgrd) lmgrd tcp-port 27001
15:41:23 (lmgrd) (@lmgrd-SLOG@) ===============================================
15:41:23 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
15:41:23 (lmgrd) (@lmgrd-SLOG@) Start-Date: Fri Feb 05 2016 15:41:23 W. Central Africa Standard Time
15:41:23 (lmgrd) (@lmgrd-SLOG@) PID: 8040
15:41:23 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.12.1.2 build 152538 i86_n3 ( build 152538 (ipv6))
15:41:23 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
15:41:23 (lmgrd) (@lmgrd-SLOG@) Socket interface: IPV6
15:41:23 (lmgrd) (@lmgrd-SLOG@) Listening port: 27001
15:41:23 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
15:41:23 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
15:41:23 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
15:41:23 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Program Files (x86)\ArcGIS\License10.3\bin\service.txt -l C:\Program Files (x86)\ArcGIS\License10.3\bin\lmgrd9.log -z -s -local
15:41:23 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  C:\Program Files (x86)\ArcGIS\License10.3\bin\service.txt
15:41:23 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
15:41:23 (lmgrd) Starting vendor daemons ...
15:41:23 (lmgrd) Started ARCGIS (pid 8048)
15:41:23 (ARCGIS) Unable to initialize access to trusted storage: 6
15:41:23 (ARCGIS) FlexNet Licensing version v11.12.1.2 build 152538 i86_n3
15:41:23 (ARCGIS) SLOG: Summary LOG statistics is enabled.
15:41:23 (ARCGIS) SLOG: FNPLS-INTERNAL-CKPT1
15:41:23 (ARCGIS) SLOG: VM Status: 0
15:41:23 (ARCGIS) SLOG: FNPLS-INTERNAL-CKPT2
15:41:23 (ARCGIS) Server started on BELKACEM for: 3DEngine
15:41:23 (ARCGIS) Aeronautical AGSData AllEurope
15:41:23 (ARCGIS) ARC/INFO ArcEditor ArcExpress
15:41:23 (ARCGIS) ArcInfo ArcMapServer ArcPress
15:41:23 (ARCGIS) ArcReader ArcScan ArcSdeConnects
15:41:23 (ARCGIS) ArcSdeServer ArcSdl ArcServer
15:41:23 (ARCGIS) ArcStorm ArcStormEnable ArcView
15:41:23 (ARCGIS) ArcView3 ArcView31 ArcView4
15:41:23 (ARCGIS) Austria AV3D1 AVArcPress1
15:41:23 (ARCGIS) Avenue AVIMAGE1 AVIMS1
15:41:23 (ARCGIS) AVIMSGIF AVLAND1 AVNetwork1
15:41:23 (ARCGIS) AVNetwork2 AVSpatial1 AVSpatial2
15:41:23 (ARCGIS) AVSurface1 AVSurface2 AVTRACK1
15:41:23 (ARCGIS) AVVRP1 BaseBISData Belgium
15:41:23 (ARCGIS) BingMaps BingMapsEng Business
15:41:23 (ARCGIS) BusinessPrem COGO Coverages
15:41:23 (ARCGIS) DataReViewer DB2 Defense
15:41:23 (ARCGIS) DefenseINTL DefenseINTLEng DefenseUS
15:41:23 (ARCGIS) DefenseUSEng Denmark Designer
15:41:23 (ARCGIS) DMTIData Editor Foundation
15:41:23 (ARCGIS) France GDBEdit GeoStats
15:41:23 (ARCGIS) Germany Grid ImageExt
15:41:23 (ARCGIS) Informix IntelAgency Internal
15:41:23 (ARCGIS) Interop InteropEngine Italy
15:41:23 (ARCGIS) JTX Luxembourg MajorRdEurope
15:41:23 (ARCGIS) Maplex MaplexEngine MappingAgency
15:41:23 (ARCGIS) MPSAtlas MrSID Nautical
15:41:23 (ARCGIS) Netherlands Network NetworkEngine
15:41:23 (ARCGIS) Plotting Portugal Publisher
15:41:23 (ARCGIS) Reader ReaderPro SchematicEngine
15:41:23 (ARCGIS) Schematics SchematicsSDK SdePersonal
15:41:23 (ARCGIS) SdeStandard SdeWorkGroup Spain
15:41:23 (ARCGIS) SpatialEngine StandardEngine StreetMap
15:41:23 (ARCGIS) StreetMapBA Survey SvrAdvanced
15:41:23 (ARCGIS) SvrEnterprise SvrStandard Sweden
15:41:23 (ARCGIS) Switzerland Sybase TIFFLZW
15:41:23 (ARCGIS) TIN Tracking TrackingEngine
15:41:23 (ARCGIS) UnitedKingdom VBA Vector
15:41:23 (ARCGIS) Viewer VirtualEarthEng
15:41:23 (ARCGIS) EXTERNAL FILTERS are OFF
15:41:23 (lmgrd) ARCGIS using TCP-port 20373
15:41:23 (ARCGIS) SLOG: Statistics Log Frequency is 240 minute(s).
15:41:23 (ARCGIS) SLOG: TS update poll interval is 10 minute(s).
15:41:23 (ARCGIS) SLOG: Activation borrow reclaim percentage is 0.
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) ===============================================
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) === Vendor Daemon ===
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Vendor daemon: ARCGIS
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Start-Date: Fri Feb 05 2016 15:41:23 W. Central Africa Standard Time
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) PID: 8048
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) VD Version: v11.12.1.2 build 152538 i86_n3 ( build 152538 (ipv6))
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) === Startup/Restart Info ===
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Options file used: None
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Is vendor daemon a CVD: No
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Is TS accessed: No
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) TS accessed for feature load: -NA-
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Number of VD restarts since LS startup: 0
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) === Network Info ===
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Socket interface: IPV6
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Listening port: 20373
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Daemon select timeout (in seconds): 1
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) === Host Info ===
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Host used in license file: BELKACEM
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) Running on Hypervisor: None (Physical)
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) LMBIND needed: No
15:41:23 (ARCGIS) (@ARCGIS-SLOG@) LMBIND port: -NA-
15:41:23 (ARCGIS) TCP_NODELAY NOT enabled
15:42:23 (ARCGIS) OUT: "ARC/INFO" BelkacemDZ@BELKACEM
15:42:25 (ARCGIS) OUT: "Editor" BelkacemDZ@BELKACEM
15:42:25 (ARCGIS) OUT: "Viewer" BelkacemDZ@BELKACEM
15:43:13 (ARCGIS) OUT: "ARC/INFO" BelkacemDZ@BELKACEM
15:43:14 (ARCGIS) OUT: "StandardEngine" BelkacemDZ@BELKACEM
15:43:14 (ARCGIS) OUT: "GDBEdit" BelkacemDZ@BELKACEM
15:43:47 (ARCGIS) IN: "GDBEdit" BelkacemDZ@BELKACEM
15:43:47 (ARCGIS) IN: "StandardEngine" BelkacemDZ@BELKACEM
15:43:47 (ARCGIS) IN: "ARC/INFO" BelkacemDZ@BELKACEM
15:44:59 (ARCGIS) OUT: "ARC/INFO" BelkacemDZ@BELKACEM
15:45:00 (ARCGIS) OUT: "StandardEngine" BelkacemDZ@BELKACEM
15:45:00 (ARCGIS) OUT: "GDBEdit" BelkacemDZ@BELKACEM
15:46:12 (ARCGIS) IN: "ARC/INFO" BelkacemDZ@BELKACEM
15:46:12 (ARCGIS) IN: "GDBEdit" BelkacemDZ@BELKACEM
15:46:12 (ARCGIS) IN: "StandardEngine" BelkacemDZ@BELKACEM
15:50:39 (ARCGIS) OUT: "ARC/INFO" BelkacemDZ@BELKACEM
15:50:39 (ARCGIS) OUT: "StandardEngine" BelkacemDZ@BELKACEM
15:50:39 (ARCGIS) OUT: "GDBEdit" BelkacemDZ@BELKACEM
RajeshDhinwa
Hi Lahmer
Please upgrade  your License Manager for ARC GIS 10.3.
Rajesh
NanaDei
Hi Lahmer,
Sorry for the late reply. Please contact Esri Technical Support if this issue is currently unresolved. We might have to review this behavior to determine a resolution.
RajeshDhinwa
Hi Lahmer
Rajesh
