Measurement Widget
1634
02-08-2016 11:25 AM
JennaWalz2
I was looking at the measurement widget at the following site. I noticed that when you close the drop-down it still lets you measure things. Is there a way to disable the measure widget when the container is closed?
Measurement Widget | ArcGIS API for JavaScript
Jenna
RobertScheitlin__GISP
Jenna,
   You click on the tool you have active again to toggle the tool off. You could add an event listener to the title panes toggle event to turn off the measure widgets selected tool.
RyanSellman
Occasional Contributor II
Hi Jenna,
Check out this link.
Edit fiddle - JSFiddle
Is this what you're after?
Ryan
