"write world file" option is blocked
3662
02-09-2016 11:59 PM
Yaron_YosefCohen
Occasional Contributor II
Hi everyone,
When i try to export map to jpg file in ArcView 10.3 (in the layout view), the "write world file" is blocked. How can i solved this problem?
i must export all the map elements in the layout view into world file.
For clarity, i asked it in Write World File option blocked when exporting Layout View in ArcGIS for Desktop? - Geographic Infor...
Thanks in advanced.
DanPatterson_Retired
And a very good set of suggestions over there!
You didn't address any of there suggestions.
Were they wrong in their assessment?
Is there some details that you haven't given to help find a solution?
There seems to be a gap between your explanation and the suggestions posted on the clarity site.
Yaron_YosefCohen
thanks, you are very helpful.
JayantaPoddar
MVP Esteemed Contributor
You could get the above result by following two simple steps
1. Exporting Map to PDF (with Georeferencing information)
Exporting to PDF—Help | ArcGIS for Desktop
2. Convert (Geo)PDF to (Geo)TIFF.
PDF To TIFF—Help | ArcGIS for Desktop
*You could export the data (TIFF) to JPEG from Table of Contents, if required.
Think Location
