Adding basemap toggle widget to 3d scene
2137
02-11-2016 06:58 AM
MeganWirth
Trying to add the basemap toggle to a 3d scene. Can some please correct me. Thanks in advance.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Polygon extrusion 3D - 4.0 beta 1</title>
  <link href='https://fonts.googleapis.com/css?family=Roboto' rel='stylesheet' type='text/css'>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
   #BasemapToggleDiv {
      position: absolute;
      top: 20px;
      right: 20px;
      z-index: 50;
   #div-test{
  position: absolute;
  top: 30px;
  right: 20px;
  z-index: 102;
div.image {
   content:url(http://maps.evansvillegis.com/Apps/Subdivisions/Scans/APC_Logos/APC_Logo_ORG_WHT_small.png);
#textbox1{
  font-family: 'Roboto', sans-serif;
  position: absolute;
  height: 50;
    width:400px;
    padding:10px;
    bottom: 40px;
  left: 40px;
  color: white;
  background-color: rgba(34, 34, 34, 0.5);
  z-index: 102;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta1/esri/css/esri.css">
  <script src="https://js.arcgis.com/4.0beta1/"></script>
  <script>
    var map, view;
    require([
      "esri/Map",
      "esri/Color",
      "esri/views/SceneView",
   "esri/widgets/BasemapToggle",
   "esri/widgets/BasemapToggle/BasemapToggleViewModel",
      "esri/layers/FeatureLayer",
      "esri/symbols/PolygonSymbol3D",
      "esri/symbols/ExtrudeSymbol3DLayer",
      "esri/renderers/SimpleRenderer",
      "dojo/domReady!"
    ], function(Map, Color, SceneView, BasemapToggle, BasemapToggleVM, FeatureLayer, PolygonSymbol3D,
      ExtrudeSymbol3DLayer, SimpleRenderer) {
      //Create map
      map = new Map({
        basemap: "dark-gray"
      //Create SceneView for 3d visualization
      view = new SceneView({
        container: "viewDiv",
        map: map,
        camera: {
          position: [-86.8757632, 37.656801, 38000],
          tilt: 60,
          heading: -60
  var toggle = new BasemapToggle({
        //Setting widget properties via viewModel is subject to
        //change for the 4.0 final release
        viewModel: new BasemapToggleVM({
          view: view,
          secondaryBasemap: "hybrid"
      }, "BasemapToggleDiv");
      toggle.startup();
      //Create featureLayer and add to the map
      var featureLayer = new FeatureLayer({
        url: "http://services1.arcgis.com/1vlgiUCSf9FiT4I0/arcgis/rest/services/CensusTractsPoverty/FeatureServer/..."
      map.add(featureLayer);
      //Create the Renderer for the featureLayer,
      var extrudePolygonRenderer = new SimpleRenderer({
        symbol: new PolygonSymbol3D({
          symbolLayers: [new ExtrudeSymbol3DLayer()]
        visualVariables: [{
          type: "sizeInfo",
          field: "POVERTY2",
          minSize: 100,
          maxSize: 1000,
          minDataValue: 9.100000,
          maxDataValue: 50.099998
          type: "colorInfo",
          field: "POVERTY2",
          minDataValue: 1,
          maxDataValue: 50,
          colors: [
            new Color("white"),
            new Color("red")
      featureLayer.renderer = extrudePolygonRenderer;
  </script>
</head>
<body>
  <div id="textbox1">
  <h3>Evansville Vanderburgh County | Poverty Data</h3>
  <p>This visualization was created by joining the <strong>Poverty Status</strong> 2010 American Community Survey 5-Year Estimates and the 2010 Census Tracts boundaries. The Tract boundaries are extruded based on the percent of people below poverty. The higher the geomtry the higher the poverty rate.</p>
  </div>
  <div id="div-test" class="image"></div>
  <div id="viewDiv">
  <div id="BasemapToggleDiv"></div>
  </div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
You should remember to check the console for errors. It was reporting that you had an unexpected "}". You inadvertently closed the require function after the toggle.startup(); line (line 91)
This seems to work
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body {
            padding: 0;
            margin: 0;
        #BasemapToggleDiv {
            position: absolute;
            top: 20px;
            right: 20px;
            z-index: 50;
        #div-test {
            position: absolute;
            top: 30px;
            right: 20px;
            z-index: 102;
        div.image {
            content: url(http://maps.evansvillegis.com/Apps/Subdivisions/Scans/APC_Logos/APC_Logo_ORG_WHT_small.png);
        #textbox1 {
            position: absolute;
            height: 50;
            width: 400px;
            padding: 10px;
            bottom: 40px;
            left: 40px;
            color: white;
            z-index: 102;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.0beta3/esri/css/esri.css">
    <script src="https://js.arcgis.com/4.0beta3/"></script>
    <script>
        var map, view;
        require([
          "esri/Map",
          "esri/Color",
          "dojo/domReady!"
        ], function (Map, Color, SceneView, BasemapToggle, BasemapToggleVM, FeatureLayer, PolygonSymbol3D,
            //Create map
            map = new Map({
                map: map,
                camera: {
                    tilt: 60,
                    heading: -60
                    view: view,
            toggle.startup();
                visualVariables: [{
                    type: "sizeInfo",
                    field: "POVERTY2",
                    minSize: 100,
                    maxSize: 1000,
                    type: "colorInfo",
                    field: "POVERTY2",
                    minDataValue: 1,
                    maxDataValue: 50,
                    colors: [
                      new Color("white"),
                      new Color("red")
    </script>
</head>
<body>
    <div id="textbox1">
    </div>
    <div id="viewDiv">
    </div>
</body>
</html>
KenBuja
This seems to work
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body {
            padding: 0;
            margin: 0;
        #BasemapToggleDiv {
            position: absolute;
            top: 20px;
            right: 20px;
            z-index: 50;
        #div-test {
            position: absolute;
            top: 30px;
            right: 20px;
            z-index: 102;
        div.image {
        #textbox1 {
            position: absolute;
            height: 50;
            width: 400px;
            padding: 10px;
            bottom: 40px;
            left: 40px;
            color: white;
            z-index: 102;
    </style>
    <script>
        var map, view;
        require([
          "esri/Map",
          "esri/Color",
          "dojo/domReady!"
            //Create map
            map = new Map({
                map: map,
                camera: {
                    tilt: 60,
                    heading: -60
                    view: view,
            toggle.startup();
                visualVariables: [{
                    type: "sizeInfo",
                    field: "POVERTY2",
                    minSize: 100,
                    maxSize: 1000,
                    type: "colorInfo",
                    field: "POVERTY2",
                    minDataValue: 1,
                    maxDataValue: 50,
                    colors: [
                      new Color("white"),
                      new Color("red")
    </script>
</head>
<body>
    <div id="textbox1">
    </div>
    <div id="viewDiv">
    </div>
</body>
</html>
MeganWirth
Thank you Ken! appreciate the help.
MeganWirth
In addition. trying to get the code i posted to work as you did Ken. I also needed to change the script links to 4.0beta3
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta3/esri/css/main.css">
hope this helps another noobster
