Pie chart renderer for JS API
4684
02-23-2016 09:16 AM
MarcBate
Occasional Contributor II
Esri, please create a pie chart renderer for the JavaScript API similar to what is available in ArcObjects for the desktop, where you can create pie charts for points whose size and slices correspond to attributes for each point.
Example pie chart from ArcMap
Has anyone found a good workaround in the meantime?
JordanBaumgardner
Occasional Contributor III
This might get you there. the esri javascript sdk support D3.js
SVG and CSS using D3 | ArcGIS API for JavaScript
RyanSellman
Hi Marc,
Check out the Dojo charting library here:
dojox.charting — The Dojo Toolkit - Reference Guide
Tim Witt​'s Census Application is a good example of how to use this library in an ArcGIS JavaScript app:
Census Data
Hope that helps!
Ryan
MarcBate
For those keeping score, this was implemented in 4.24, a mere 6 years after this post.
