Web Application Builder url http/https
6030
02-25-2016 09:54 AM
RobertHarris5
New Contributor III
Hi, sorry for the long winded question but here goes...
I have Server 10.3.1 with Portal for ArcGIS 10.3.1. installed behind a firewall.
I have configured ArcServer with LDAP Authentication
I have configured the arcserver web adaptor with anonymous
I have published the portal web adaptor with windows authentication
I created a map in portal. All of the services require https. Very simply, when I create a web application from the map using web appbuilder, it automatically creates a link with an http at the beginning. See below:
http://ourmachinename.ourdomain.local/portal/apps/webappviewer/index.html?id=thismapsid (its behind our firewall, I removed any reference to our domain information)
When I initially launch the app, it is an https link.
After the launch, when I view the url it is an http link.  However every time I try to save the new link the changes won't stay. It doesn't matter if I'm logged in as site admin or as myself (Also admin). Basically, I want to share this application as a featured map and app, but when any end user tries to access it they receive a
403 - Forbidden: Access is denied.
You do not have permission to view this directory or page using the credentials that you supplied.
Is there a way to override the http setting for the applications?
I'm not a developer, I'm just testing portal configurations on a test box. Hoping to stay OOB as much as possible.
RobertHarris5
New Contributor III
The solution for us ended up being how we were logging into and creating apps in portal. I was logging in as site admin https://ourserver.ourdomain.local:7443/arcgis/home/index.html   What I did to resolve this was to log in as myself ( https://ourserver.ourdomain.local/portal/home/index.html ), create and configure my map and app. When all was said and done i switched to owner to the site admin account, assigned to groups and the link didn't change. If i need to reconfigure the app, i switch the owner back to me. Not ideal, but it works.
ShaneApplegate
Were you ever able to figure out how to resolve this? We are experiencing a similar issue.
We did find a workaround where we removed the portal domain entirely and just left the webapp path.
Example:
Original URL: http://portal.gis.com/portal/apps/webappviewer/index.......
New URL: /portal/app/webappviewer/index.........
When we saved the new URL, it would not change back to http and would allow for users to view the app. However, it is a pain to have to go in and change the URL every time that you create a webapp, so if there was a way to permanently change the URL to https that would be a much better solution.
RobertHarris5
New Contributor III
