run local moran's index in all fields automatically
2055
03-12-2016 10:22 AM
KleoT
I want to use the local moran's I index. I have a table/layer with 50 columns. Can I execute moran in all fields of this table automatically? or i should run the tool 50 times?
Thanks!
Tags (1)
DanPatterson_Retired
manually ... because you have important decisions to make along the way
Cluster and Outlier Analysis (Anselin Local Moran's I)—Help | ArcGIS for Desktop
Local Moran's I Additional Math—Help | ArcGIS for Desktop
How Cluster and Outlier Analysis (Anselin Local Moran's I) works—Help | ArcGIS for Desktop
should you feel confident that this specific tool applies to your situation and you meet all the conditions, then you could automate it, but I would first of all question doing 50 in the first place... it sounds like data leading the analysis rather than the other way around.
KleoT
In my case, all the fields will have the same options checked. It will be the exact same precedure 50 times. This is why I want to automate it somehow.
I am talking about the data meeting the requirements, not the checked options.
