error 001795
5125
04-03-2016 10:59 PM
YvonneMaher1
I am trying to Package a Project in ArcGIS Pro.  The Analyze tick appears with no errors. Then when I try to package it, I get ERROR 001795: Failed to consolidate project due to problem with Geoprocessing History item: Copy Features.  I removed the Copy Features from the Geoprocessing History but the error persists.  Does anyone have a solution for this problem?
Tags (1)
PanGIS
Occasional Contributor III
Hi Yvonne,
I had the same problem. I could solve only by deleting all the GP history.
Don't know whether is the solution but at least I could package.
SusanTran
Error 1795 may appear if an item in your Geoprocessing History has an error and cannot be packaged.  To resolve the issue, go to the Project Pane > Geoprocessing History and remove any items with errors.
Robert_LeClair
Esri Notable Contributor
Does your Pro project contain a model?  And if so, are you using the Make Feature Layer command in the model as well?  Another thing to check - are you using tasks at all?  Pls advise.
