Web AppBuilder v2 Installation Error
5256
5
04-04-2016 01:22 PM
JillianStanford
Occasional Contributor III
I've downloaded and extracted the latest version of WAB but when I run startup.bat I get the following error:
fs.js:653
  return binding.mkdir(pathModule._makeLong(path),
Error: EPERM, operation not permitted 'C:\Program Files\WebAppBuilderForArcGIS\server\logs'
    at Object.fs.mkdirSync (fs.js:653:18)
    at Object.<anonymous> (C:\Program Files\WebAppBuilderForArcGIS\server\server.js:73:6)
    at Module._compile (module.js:456:26)
    at Object.Module._extensions..js (module.js:474:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:312:12)
    at Function.Module.runMain (module.js:497:10)
    at startup (node.js:119:16)
    at node.js:906:3
Press any key to continue . . .
I thought maybe it was a permissions problem so I ran startup.bat as an administrator and now I simply get the error:
"server" directory does not exist
The server directory definitely exists. It contains 17 files and 3 directories. I've deleted everything and downloaded a fresh copy but still get the same error. Node.js is installed from a previous version of WAB.
Ideas?
Thanks!
Jill
RobertScheitlin__GISP
Jill,
  Have you tried to unzip WAB to the c: root instead of C:\Program Files?
Jill,
JillianStanford
You are right on, Robert. This worked.
Strange that I have installed v2 on other workstations in C:\Program Files without problems.
Thanks for the reply, I really appreciate it!
Jill
AbhayDuvvuri2
I have the extracted WAB in C:\WebappBuilderForArcGIS and when executing startup.bat, I still get the following error:
AlfredoConetta1
I had a similar issue that seems to be sorted by extracting the file to the C:\ , as suggested above.
