NearMe not working in Tab theme.
2665
04-11-2016 11:14 AM
StanMcShinsky
Occasional Contributor III
From what I can tell the new NearMe widget is not working either in AGOL or in the Developers Edition 2.0 with the Tab Theme. Thanks for your help.
-Stan
StanMcShinsky
OK I found that it only happens when the NearMe widget is loaded in the side panel in the Tab theme. Lucky me, right where I need it. Also customer support told me it is a known issue for that theme and will be fixed someday.
Not sure what the repercussions are but I did this and it works so far:
I commented out the lines that say:
dijit.byId(this.domNode.parentElement.id).resize();
in [App#]\Widgets\NearMe\Widget.js line 668
and
dijit.byId(this.parentDiv.id).resize();
in [App#]\Widget\NearMe\item-list.js lines 178, 185, 449, 530, 573, 652, 814 and 891
The error says that resize is undefined so I got rid of it. It would be better to just define it but I don't know how to do that.
So far with this method it does not report the correct feature count after the identify.
StanMcShinsky
and
LindsayThomas
Hi Stan,
Thanks for reporting to the group.
I wanted to let you know that we fixed this in the July 2016 Release of Web Appbuilder for ArcGIS, and Web Appbuilder Developer Edition 2.1.
-Lindsay
