how to create enterprise GDB with Arcgis destkop 10.2 and Oracle 11g
6516
04-09-2016 05:33 AM
kendiekenmoe
Hello I am unable to create enterprises Database on Oracle 11g (11.2.0.1) from arcgis Desktop 10.2.2 I use windows server 2012
I edit the file "extproc.ora" but it does not pass
Thank you for your help
This is my oracle interface
AdrianWelsh
MVP Honored Contributor
Hi Kendie,
Have you installed the Oracle 11g Client that is required for this to work?
Oracle Database 11g Release 2 for Microsoft Windows (x64)
George_Thompson
Esri Frequent Contributor
Hi Kendie,
The base supported version of Oracle for ArcGIS 10.2.2 is 11.2.0.3
System Requirements
(Highly recommend to be using 11.2.0.4 - 44687 - Issues related to Oracle 11.2.0.3 ). Support on Windows Server 2012 for Oracle is 11.2.0.4 (*Windows Server 2012 support begins at ArcGIS 10.2.1 on Oracle 11.2.0.4 and 12.1.0.1)
Please be sure to review this documentation on Creating an Enterprise Geodatabase on Oracle: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
If you have an error along the way please respond with the error and screen shots, if possible.
GeodatabaseEnterprise GIS
-George
--- George T.
kendiekenmoe
Hi George
George thank you
I changed the software according to your recommendations.
I use now
windows server 2008
Arcgis server 10.2.2
Arcgis server 32-bit 10.2.2
I installed it on the same machine and I can not always connected to me.
you can get an idea of the problem?
by Anonymous User
Not applicable
Kendie
We won't be able to help you if you do not specify the problem/error you are experiencing....
Regard
Jesús de Diego
