AGSGraphicsLayer unique render values in leged
4755
6
04-12-2016 02:18 PM
MaximoMobile
I am trying to get the  unique render values in legend but its giving me an error , i can't get images for unique values in render  , any help would be appreciated.
SuganyaBaskaran1
What error are you getting? Can you post your code so I can take a look? Thanks.
Suganya
MaximoMobile
I know i am doing something wrong , dont know where though , i want individual images for legend but its not coming and its crashing the app
+ (AGLegendInfo*)infoForGraphicsLayer:(AGSGraphicsLayer*)layer
    AGLegendInfo *legendInfo = [[AGLegendInfo alloc] init];
    NSMutableArray *legendInfos = [[NSMutableArray alloc] init];
    AGSRenderer *renderer = layer.renderer;
    AGLegendInfoType *info = [[AGLegendInfoType alloc] init];
    AGSGraphic *g = [[AGSGraphic alloc]init];
    UIImage *image = [[UIImage alloc]init];
    if ([layer.renderer isKindOfClass:[AGSUniqueValueRenderer class]])
        NSLog(@"AGSUniqueValueRenderer");
        AGSUniqueValueRenderer *renderer = (AGSUniqueValueRenderer *)layer.renderer;
        int num = [renderer.uniqueValues count];
        NSLog(@"%d", num);
        for (int j = 0 ; j < num ; j++)
            AGSUniqueValue *value = [renderer.uniqueValues objectAtIndex:j];
            g = [layer.graphics objectAtIndex:j];
            image = [renderer swatchForFeature:g size:CGSizeMake(20, 30)];
            legendInfo.defaultSymbol = image;
            [legendInfos addObject:legendInfo];
            //[legendInfos addObject:legendInfo];
            legendInfo.layerName = layer.name;
            legendInfo.types = [[NSArray alloc] initWithArray:legendInfos];
    return legendInfo;
MaximoMobile
after number iterations  , i am still getting this error
'NSInvalidArgumentException', reason: '-[AGLegendInfo typeName]: unrecognized selector sent to instance 0x7fec1b790380'
does any one have steps to get the unique render legend from graphics layer , i could not get  images using swatchForFeature for values in unique render , i dont know which graphics i should send to get the image
any idea???? please
SuganyaBaskaran1
I see you are using AGLegendInfo class. Is that meant to be AGSLegendInfo?
Which version of the SDK are you using (or intend to use)? I ask because AGSLegendInfo class is present only in the Quartz beta release and AGSGraphicLayer is in 10.2.5 (AGSGraphicsOverlay in Quartz)
MaximoMobile
no its not AGSLegendinfo , I have create my own class. the issue is the
render does not send all the types in.
but requirement has change now as users want those render values as a layer
that they can turn on and off
So I have to create individual layers for those render value. you may
solve my other issue , can i create a dynamic variable for
AGSGraphicsLayer
like i have to create all these AGSGraphicsLayer with different type of
statuses
AGSGraphicsLayer* APPRmyGraphicsLayer = [AGSGraphicsLayer
graphicsLayer];
AGSGraphicsLayer* COMPmyGraphicsLayer = [AGSGraphicsLayer
graphicsLayer]; ... and so on
why i cant do something like
NSSet *uniqueStatus = [NSSet setWithArray:[objects valueForKey:@"status"
int numElement = uniqueStatus.count;
NSMutableArray *gr = [[AGSGraphicsLayer alloc]init];
for (NSString *item in uniqueStatus) {
or
AGSGraphicsLayer *gr = [[AGSGraphicsLayer alloc] init];
NSLog(gr.name);
both gives me an error , the layer gets added to map but i cant add
geometry to it as its not an unique name layers
SuganyaBaskaran1
Please send a sample project that would reproduce the issue so we can take a look.
