Using relative paths for your batch files??
3256
04-17-2016 07:38 AM
JonahWaterman
New Contributor III
I have setup a python script to run a Table to Table Comparison using Data Reviewer. I am moving the script around to various folders for sharing purposes, everything runs properly however the script fails when it tries to locate the batch file, how can I enable relative paths with the batch files. Thanks
Looks like the only way is to reconfigure the .rbj file through notepad using a script. Any advice would be great.
MichelleJohnson
Jonah, it's been a while since I've been on GeoNet.  Did you get this resolved?
Are you using the Execute Reviewer Batch Job GP tool to run the Table to Table Attribute comparison?  In that dialog, you can pass in the production workspace and it will update the path of the resources in the RBJ file to the one you pass in that optional parameter.
