Runtime crash on IPhone
3953
04-18-2016 08:12 PM
梦竹许
- Using the ArcGIS iOS SDK specifically on iPhone, a consistent suddenly close always happen when attempting to solve a route offline. The stack trace always returns the following function:
Esri_runtimecore::Network_analyst::Traversal_result::get_partial_edge_geometry_(Esri_runtimecore::Geodatabase::Transportation_network_view::Source_object_range, std::__1::shared_ptr<Esri_runtimecore::Geometry::Geometry> const&, std::__1::shared_ptr<Esri_runtimecore::Geometry::Polyline>&, bool, double, double) const ()
I want to know why this crash happens,
Thanks for any feedback,
Tags (1)
SuganyaBaskaran1
Hi, thanks for reporting. This is a known issue with 64 bit devices and we'll work on fixing it in the next release.
Can you try this workaround? Build the project with only 32 architectures. You can then run the app on all devices without a crash - the trade off being you would be unable to benefit from 64-bit computing.
Suganya
梦竹许
Thanks for your replyling.
Building the project with only 32 architectures can solve the problem ,but it seems that 5 and later's devices use 64bit。The problem is whether I can use 32 architectures only to pass the  'check.I heared that if my project is using 32architectures only, I can't pass the check and my application can't be on shelf.
发自 网易邮箱大师
在2016年04月20日 01:24,Suganya Baskaran 写道:
GeoNet
reply from Suganya Baskaran in ArcGIS Runtime SDK for iOS - View the full discussion
Suganya
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS Runtime SDK for iOS by email or at GeoNet
Following Runtime crash on IPhone in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
