Hi all,
I'm trying to set a different behavior of the Popup Panel Widget on map click for each layer.
For a particular layer, I need to retrieve data from a webservice passing a field value as parameter.
Is it right what I'm trying to do or you think I have to move this code somewhere else?
at the moment the line 10 gave me an error:
TypeError: this.own is not a function
startup: function () {
this.inherited(arguments);
var map = this.map;
LayerInfos.getInstance(map, map.itemInfo).then(lang.hitch(function(operLayerInfos) {
operLayerInfos.getLayerInfoArray().forEach(function(layerInfo) {
if (layerInfo.title == 'Map') {
var layerId = layerInfo.id;
console.log('layer ID = ', layerId);
var layer = map.getLayer(layerId);
this.own(on(layer, "click", lang.hitch(this, this.onMapClick)));
this.displayPopupContent(this.popup.getSelectedFeature());
onMapClick: function(event) {
//I want to disable the normal behavior of the click (retrieve data and populate the Popup Panel widget with my customized content)
var queryTask = new QueryTask('*Service URL*');
var query = new Query();
query.returnGeometry = true;
query.outFields = ['*'];
query.geometry = event.mapPoint;
queryTask.execute(query, lang.hitch(this, this.showResults));
showResults: function(results) {
var resultItems = [];
var resultCount = results.features.length;
for (var i = 0; i < resultCount; i++) {
var featureAttributes = results.features.attributes;
var URL = "theWebServiceUrl" + featureAttributes.NAME;
//and I want to pass this URL to call it with through esri/request and retrieve data and then populate the PopUp Panel
Naty
Solved! Go to Solution.
Naty,
The search Widget adds the search result to the maps graphics layer and thus does not have a layer property.
Here is what I think you should do:
this.own(on(this.popup, "selection-change", lang.hitch(this, function () { var gra = this.popup.getSelectedFeature(); if(gra){ console.info(gra); var layer = gra.getLayer(); if(layer && layer.name === "map"){ console.info(layer.name); var URL = "theWebServiceUrl" + gra.attributes.NAME; console.info(URL); //this will prevent it from going to the function that displays the popup info return; }else if(gra.attributes.hasOwnProperty("yourspecificfieldname")){ var URL2 = "theWebServiceUrl" + gra.attributes.NAME; console.info(URL2); //this will prevent it from going to the function that displays the popup info return; } } this.displayPopupContent(this.popup.getSelectedFeature()); })));
On line 12 you will have to determine if this is a search result graphic and if so is it one you are interested in. The problem is you are using such a common field name "NAME" so many graphics beside your specific layer use that field name.
Naty,
That is because line 10 is inside a function that is not scoped:
See line 6 and 13
startup: function () { this.inherited(arguments); //I don't understand why people add a local var for map when they have access to the map using this.map... //var map = this.map; LayerInfos.getInstance(this.map, this.map.itemInfo).then(lang.hitch(function(operLayerInfos) { operLayerInfos.getLayerInfoArray().forEach(lang.hitch(this, function(layerInfo) { if (layerInfo.title == 'Map') { var layerId = layerInfo.id; console.log('layer ID = ', layerId); var layer = map.getLayer(layerId); this.own(on(layer, "click", lang.hitch(this, this.onMapClick))); } })); } )); this.displayPopupContent(this.popup.getSelectedFeature()); },
Robert, I made changes and I removed local var "map"
startup: function () { | ||
this.inherited(arguments); | ||
var layer; | ||
LayerInfos.getInstance(this.map, this.map.itemInfo).then(lang.hitch(function(operLayerInfos) { | ||
operLayerInfos.getLayerInfoArray().forEach(lang.hitch(this, function(layerInfo) { | ||
if (layerInfo.title == 'Map') { | ||
var layerId = layerInfo.id; | ||
console.log('layer ID = ', layerId); | ||
layer = this.map.getLayer(layerId); | ||
this.own(on(layer, "click", lang.hitch(this, this.onMapClick))); | ||
this.displayPopupContent(this.popup.getSelectedFeature()); |
It runs without error but onMapClick doesnt run when I click on the map..
I tried to log something:
console.log("onMapClick runs");
but nothing happened...
Naty
Naty,
Have you tried a console.info(layer); to be sure that you sound the layer?
Robert, I tried with this code:
var layer,layerId;
console write all the info of the layer...but...nothing happens on onMapClick event...
Naty
Naty,
Well I should have asked if that layer is a sublayer of a dynamic map service or is it an actual featurelayer?
i has sublayers and i need to use this popup in one of them.
thanks,
Naty
Naty,
Then I was wrong you do need to switch back to the map on click instead of the layer as then is nothing to fire a click event for when using a dynamic map service.
Robert thanks for your patience with me..
So, what can I do? I can change my Services, too...
Naty
Naty,
Re-evaluating what your goal is this is actually much simpler than you road we started down. Update this portion of the Widget.js:
this.own(on(this.popup, "selection-change", lang.hitch(this, function () { var gra = this.popup.getSelectedFeature(); var layer = gra.getLayer(); console.info(layer.name); if(layer.name === "map"){ var URL = "theWebServiceUrl" + gra.attributes.NAME; //this will prevent it from going to the function that displays the popup info return; } this.displayPopupContent(this.popup.getSelectedFeature()); })));
