Tiled map service slow on large ipads
2649
04-26-2016 01:10 PM
KristofferStenersen
The following is a screen capture running one of the examples consuming a tiled map service
slow tile rendering.mov - Google Drive
Tile fetching is slow. Running a similar test using the js-apis (on the same network) - stuff runs fast.
Kristoffer
Tags (1)
MichaelVolz
Esteemed Contributor
Is the tiled service by any chance created from an Image Service where you are using it in the BaseMap Switcher?
MichaelDavis3
Occasional Contributor III
This is recorded using the iOS simulator correct?
Do you experience the same thing on a physical device?  I've noticed a marked difference in drawing speed on the simulator - especially when emulating devices with retina displays.  I assume the host Mac is working overtime to simulate the GPU.
