myMapTip.Title = item.Value.ToString();
myMapTip.Height = 300;
myMapTip.Width = 300;
graphic.MapTip = myMapTip;
myMapTip.GraphicsLayer = graphicsLayer;
This code shows my tool tip with the attribute data but the attribute data hides after just a few seconds, any suggestions to keep the attribute data visible?
The MapTip should be visible the entire time the mouse is over the Graphic. You see the MapTip source here as part of the open source toolkit: arcgis-toolkit-sl-wpf/MapTip.cs at master · Esri/arcgis-toolkit-sl-wpf · GitHub
Cheers
Mike
