We have downloaded the 3.3 API Sample code found here. Using Editing -> Feature Data Form example:
The FeatureDataForm displays Domains properly as dropdowns for this URL -
Layer: Water Network Structures - City View (ID: 20)
But does not for this URL.
Layer: Water Hydrants - Block View (ID: 22)
It appears layers with "Types" are the only featurelayers that work correctly.
Are there new requirements for publishing services or is there a bug in the 3.3 Toolkit FeatureDataForm?
Darell
Solved! Go to Solution.
We modified the Toolkit by changing the FeatureDataForm.cs -> GetControlType() back the same as it was in 3.1. This appears to be working for us.
