which coordinates send?
1960
05-10-2016 07:01 PM
CloudingSoft
Hi I continue with thehttp://resources.arcgis.com/en/help/arcgis-rest-api/#/Vehicle_Routing_Problem_service/02r3000000n400...
I am sending a url with all the data and get the jobId OK
but when I check the status of jobId always gives me "esriJobFailed"
investigation found that I am sending wrong coordinates "orders" and "depots"
& Orders = { "features": [{ "geometry": { "x": - 4283666882700000, "y": - 5094167652999600} ...
& Depots = { "features": [{ "geometry": { "x": - 4283666882700000, "y": - 5094167652999600} ...
I did a test example and you put these coordinates manually
for orders:
{ "x": - 122.4889, "y": 37.7538}
for depots:
{ "x": - 122.4739, "y": 37.7432}
and get REQUEST status "esriJobSucceeded" !!!
as I can convert my coordinates to the correct coordinates?
Thank you
CloudingSoft
Hi I realized I had to add the parameters SpatialReference, in my case my coordinates are type wkid 4326
SpatialReference ": {" wkid ": 4326}
but when I query I still returns FAILED state
RobertScheitlin__GISP
Fabien,
  Sounds like you need to convert your Webmercator coords to Geographic coords. For that use WebMercatorUtils:
esri/geometry/webMercatorUtils | API Reference | ArcGIS API for JavaScript | webMercatorToGeographic
CloudingSoft
Hello, my coordinates use these coordinates.
but I found that if sending the type of coordinates of example SpatialReference default the script works.
According to documents if I send other cooredenadas must specify the SpatialReference, yet fails.
