travel mode as a param of routeTask.solveWithParameters?
4111
05-11-2016 10:21 PM
DanielCosta2
Guys, I'm trying to get travel time from the iOS SDK, but a parameter for that doesn't seem to exist just like the one we have at the JS SDK.
I'm using this code to solve the Route:
       if self.routeTask == nil {
            self.routeTask = AGSRouteTask.routeTaskWithURL(NSURL(string: "http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World"), credential: cred) as! AGSRouteTask
             self.routeTask.delegate = self
        let params = AGSRouteTaskParameters()
        let firstStop = AGSStopGraphic(geometry: myLocation, symbol: nil, attributes: nil)
        let lastStop = AGSStopGraphic(geometry: destination, symbol: nil, attributes: nil)
        params.setStopsWithFeatures([firstStop, lastStop])
        params.returnRouteGraphics = true
        params.returnDirections = true
        params.findBestSequence = false
        params.preserveFirstStop = true
        params.preserveLastStop = true
        params.outSpatialReference = self.mapView.spatialReference
        params.ignoreInvalidLocations = false
        self.routeTask.solveWithParameters(params)
Can you guys help me how to achieve that here? I didn't find anything at the documentation!
Thanks a lot!
DiveshGoyal
AGSRouteResult has properties like totalMinutes, totalMiles, etc that you can use.
10.2.5: AGSRouteResult Class Reference
But you'll probably have to set up the accumulateAttributes of AGSRouteTaskParameters to include the time and distance attributes.
10.2.5: AGSRouteTaskParameters Class Reference
This is how it is done by the offline routing sample - arcgis-runtime-samples-ios/ViewController.swift at master · Esri/arcgis-runtime-samples-ios · GitHub... - but you might have to change the attribute names to match the ones that are available with the  route.arcgis.com service
DanielCosta2
Thanks for your answer, Divesh!
But maybe my question wans't clear enough, as I already have all those attribuites in hand:
I need to get the estimated travel time (and also the best route) not by driving, as the standard task returns me, but by walking.
I have an app for an open space urban exposition, and people will visit each location walking from one place to another. Right now, all routes I got are related to car driving.
Is it possible to achieve with the iOS SDK?
In the other hand, if I was the one who misunderstood your answer, could you show me an actual example to achieve walking routes and times?
Thanks a lot!
