Graphic always shows at mappoint 0,0 while using latitude and longitude
3279
05-12-2016 04:20 AM
DeepakBhatia
Hi I am using this code to add a Text SYmbol at given latitude and longitude.(San Francisco)
TextSymbol txtSymbol = new TextSymbol(30, "50", Color.BLUE);
     Point mapPoint = ConvertMyLocationPoint(-122.4600595,37.7532508);
     gr = new Graphic((mapPoint), txtSymbol);
     graphicsLayer = new GraphicsLayer();
     //add the graphic to the map
        graphicsLayer.addGraphic(gr);
        mMapView.addLayer(graphicsLayer);
private Point ConvertMyLocationPoint(final double longitude, final double latitude) {
  Point wgspoint = new Point(longitude, latitude);
  Point mapPoint = GeometryEngine.project(longitude,latitude,
   mMapView.getSpatialReference());
   return mapPoint;
The point always shows up at 0,0(lat, long) in the map.
Is this a wrong way to add point when I have latitude and longitude?
Could anyone suggest how to approach this.
Thanks.
ShellyGill1
Hi Deepak,
I could see anything that looked wrong with your code - I put this into an app, and found the '50' text symbol displays at San Francisco as expected. The ConvertMyLocationPoint function returned a Point like this:
    mapPoint.getX() - -1.3632191466053985E7
    mapPoint.getY() - 4544626.829865076
How is your MapView defined? That's where the coordinate system is being taken from, so I wonder if that is the problem in your case. Here is the MapView definition I was using - as I'm using the Esri basemaps, the spatial reference is Web Mercator Auxiliary Sphere (id = 102100).
<com.esri.android.map.MapView
   android:id="@+id/map"
   android:layout_width="fill_parent"
   android:layout_height="fill_parent"
   mapoptions.MapType="Streets"
   mapoptions.ZoomLevel="1"
What is the Spatial Reference that you're projecting the point to? Does the returned Point definately have 0,0 as coordinates?
Regards
Shelly
