ArcCatalog 10.2.2 shutdown really slow.
2353
05-13-2016 08:47 AM
FrankOgiamien
When I exit ArcCatalog it takes about 2 minutes with a "Not responding" message at the top of the app.   What would cause this?   I have the application installed on a SSD drive.  Any ideas how to speed this up?  Thanks
curtvprice
MVP Esteemed Contributor
Have you tried clearing the geoprocessing history?
Using the Results window—Help | ArcGIS for Desktop
Viewing tool execution history—Help | ArcGIS for Desktop
A more brute force solution to "clear things out" would be:
Resetting your ArcGIS application profile
which is a good idea every now and then.
curtvprice
FrankOgiamien
Hey thanks that was the problem!   I changed the "Keep results younger than:" value to Never Save.   Now it exits in under a second.
