How to save the Map to JPEG or PDF format?
3818
12-02-2010 12:37 PM
DanDong
Hi all,
I want to save MyMap to JPEG or PDF format to local computer, how can I do this in the C#&silverlight codes? Any suggestions? Thank you:)
JenniferNery
These are related threads:
http://forums.arcgis.com/threads/6118-Uploading-a-map-to-an-image
http://forums.arcgis.com/threads/17564-Print-map-sample
http://forums.arcgis.com/threads/8582-Create-PDF
You can put key words in Advanced Search and choose Silverlight/WPF Forum to see if other people have encountered the same issues. It's usually the fastest way to find answers  🙂
DanDong
Thank you Jennifer! I used key words to search related thread. I just thought that maybe there is other simple ways to save MyMap into local computer with pdf or jpg format.
I went through the "Creat PDF" thread, I tried the method, then I think what Dominique said is the most convenient way to save the map as a pdf file by using PDF printer. So right now I can use this way. But I will ask my team leader for sure.
