Unable to publish map service with data in enterprise database using Server 10.4
30517
45
05-24-2016 03:57 AM
ThomasPuthusserry
New Contributor III
I have upgraded ArcGIS Server 10.3.1 to 10.4 and facing issues with publishing map services with data stored in enterprise databases.
The server is hosted in Amazon AWS with following infrastructure and works fine:
Windows 2012 R2
Server 10.3.1
PostgreSQL 9.3 (in the same server - localhost) with SDE enabled
PostgreSQL as AWS RDS with SDE enabled
However, when the server upgraded to 10.4, the service with data in enterprise databases (both localhost and AWS RDS) which used to publish are no longer working. The error is
The ArcServer log file shows the following details
Error executing tool. PublishServiceDefinition Job ID: j5a9a52478ffc49d19328e5ceefbb609f : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details. ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition).                System/PublishingTools.GPServer
Failed to create the service.: Updating the server connection string for layer sdedb1.web.%gwstatmaster_staging Events failed. Attempted connection string was ENCRYPTED_PASSWORD=00022e68334e624d44786b57627653553542393435702b3845413d3d2a00;SERVER=xxxxxxx.c11tt3rfoa7s.eu-west-1.rds.amazonaws.com;INSTANCE="DSID=a8960749-e49c-41db-a095-a8a257a693b4";DBCLIENT=postgresql;DB_CONNECTION_PROPERTIES=xxxxxx.c11tt3rfoa7s.eu-west-1.rds.amazonaws.com;DATABASE=sdedb1;USER=web;VERSION=sde.DEFAULT;AUTHENTICATION_MODE=DBMS. Table name is sdedb1.web.%gwstatmaster_staging. Please verify the data exists on the server.                System/PublishingTools.GPServer
If I uninstall 10.4 and reinstall 10.3.1 on the same server, everything back to normal and working fine.
Has anyone else experienced the same issue?
Thanks and any suggestions much appreciated
Thomas
TanuHoque
Thanks Thomas... i'm glad that in the end it worked for you though as you say it is not straight forward.
My bad about option#1... i realized later that that wouldn't help in this case.
for future reference, here is a boilerplate json to create a map service from the Admin site.
update values for 'serviceName' and 'filePath' and you should be fine.
    "serviceName": "<mapservice_name>",
    "type": "MapServer",
    "description": "",
    "capabilities": "Map,Query,Data",
    "provider": "ArcObjects",
    "clusterName": "default",
    "minInstancesPerNode": 1,
    "maxInstancesPerNode": 1,
    "instancesPerContainer": 1,
    "maxWaitTime": 60,
    "maxStartupTime": 300,
    "maxIdleTime": 180,
    "maxUsageTime": 600,
    "loadBalancing": "ROUND_ROBIN",
    "isolationLevel": "HIGH",
    "configuredState": "STARTED",
    "recycleInterval": 24,
    "recycleStartTime": "00:00",
    "keepAliveInterval": -1,
    "private": false,
    "isDefault": false,
    "maxUploadFileSize": 0,
    "allowedUploadFileTypes": "",
    "properties": {
        "useLocalCacheDir": "true",
        "outputDir": "C:\\arcgisserver\\directories\\arcgisoutput",
        "cacheDir": "C:\\arcgisserver\\directories\\arcgiscache",
        "filePath": "C:\\temp\\mymap.msd",
        "maxRecordCount": "1000",
        "supportedImageReturnTypes": "MIME+URL",
        "clientCachingAllowed": "true",
        "isCached": "false",
        "virtualOutputDir": "/rest/directories/arcgisoutput",
        "maxExportTilesCount": "100000",
        "ignoreCache": "false",
        "exportTilesAllowed": "false",
        "cacheOnDemand": "false"
    "extensions": [],
    "frameworkProperties": {},
    "datasets": []
AstridGladys1
Hi
Did you try to save your mxd as a new one in order to get a mxd in 10.4 ?
Best,
Astrid
JonathanQuinn
Esri Notable Contributor
Is that query layer?  I'm curious as to why there's a % sign in the table name:
ThomasPuthusserry
New Contributor III
Yes, this is a query / view from PostgreSQL in AWS RDS
BrianOevermann
Occasional Contributor III
If you drag and drop a database table into ArcMap vs. using the Add Data dialog, the drag and drop process adds a percent sign to the table name. The Add Data dialog process does not.
I found this bug at version 10.2 while using the Flex Viewer. At first I thought it was a Flex widget issue. That was not the case. I opened a support ticket and we eventually found the workaround. Apparently there is a bug that was logged at v. 10.1 regarding this. [#NIM093503] Apparently the bug has not been resolved.
FWIW, ArcMap seems perfectly happy with the percent sign. Publishing a map service--or maybe consuming said published map service--is where the issues creep in.
Bug report:
http://support.esri.com/bugs/nimbus/TklNMDkzNTAz
My initial forum post regarding my issue along with multiple updates:
https://community.esri.com/thread/90592
Doesn't solve the original question but answers the "percent sign in the table name" question...
Brian
BrianGallegos
New Contributor III
I have come across this publishing issue from time to time for a little while now.  Adding the data through the tool rather than drag and drop worked today!  I'm pretty sure this has been my issue in the past, so nice to know what's been going on finally!
Thanks Brian
MichaelJenkins
Thank you, Brian!   This perfectly describes the mystery what we were trying to solve.   A table from a non-spatial DB brought in to ArcMap (drag an drop) and joined to a feature class.   No problem in ArcMap, and no problem publishing to ArcGIS Server, but "incorrect SQL" errors when we try to query that layer if we specify any of the table fields because the table name has a % added to the beginning.
GISP
MarkLittell
New Contributor III
I am experiencing the same issue - has anyone found a solution?
Jonathan Quinn - Yes it is a query layer.
I do not want to re publish 90+ services by going back to 10.3.1.
I am trying to use 10.4.1
Please advise
- Mark
ChristianWells
Hi Mark,
There are some defects regarding publishing in 10.4 that we have identified for some layer types. Are you able to open a Esri Support case so we can attach you to the defects as appropriate?
BUG-000096292: When the database view is joined to a definition que..
Christian
MarkLittell
New Contributor III
ESRI's Alternate Solution does not work either.
I uninstalled ArcMap 10.4.1 and installed 10.3.1, tried to publish the layer, and get the same error.
Current ArcMap is 10.3.1.4959
Current ArcGIS Server is 10.41
I do not want to revert back to server 10.3.1 - I have over 90 services that will need redeploying.
Should I start a new thread?
