What is the way to divide a long table in two continous according to my map layout using Production mapping? My table has 107 rows which is so long according to the map layout, so i want to divide it in two continous tables. By using "Insert, Graphic Tabl
1484
05-25-2016 03:52 AM
MamadouDiabate
My table has 107 rows which is so long according to the map layout, so i want to divide it in two continous tables. By using "Insert, Graphic Table Element, i follow thw process to select the target layer...
FC_Basson
MVP Regular Contributor
I would rather use Excel to do it.  You can convert your table to Excel, where you can split the columns in two, apply formatting, select all the data, copy to clipboard, paste in your map layout.  Much easier!
